Question about GE WBSR3140DW Top Load Washer
Washer won't turn off
Twice now about two months apart the machine just keeps running ,going from cycle to cycle . the first time unpugging it and plugging it back in worked. this time I had to unplug it for hours, overnight.
  • diane08840 Jan 05, 2009
    My machine wouldn't stop spinning, even when pushing in the button. I unplugged it, but when you plug it back in, it's making a humming noise.
  • 163 Answers
Hi!! You need a new timer for your washer machine..they can be very expensive so look around..Good luck..
Posted on Jan 04, 2009
Machine stops part way through the cycle and the light keeps flashing
hi there could be a few problems here 1 check the filter if has one 2 check drain hose at the back of the washer 3 check water pipe make sure there's water going into the machine 4 check pump underneath the washer hope it helps
regards
shaun
Nov 17, 2011 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Daewoo DWCLD1013 washer & dryer The cycle keeps getting stuck on spin at around 10minutes, at which time it keeps going round and round with no actual fast spinning, until it stops about 20 minutes...
The cycle that the machine is stuck in is in fact the empty cycle, just before the spin kicks in. It is staying there because it has a problem evacuating all the water. The machine won't go into spin until all the water is gone and after a set time ( 20 minutes is unusually long, most machines stop after about 10,, but I'm not familiar with Daewoo), the attempt to empty is aborted and the machine stops.
Your problem therefore is either:
The filter for the empty pump is clogged with debris (far and away the most likely) you will need to locate and clean the filter
The EXIT to the drain is blocked, check the empty pipe is not blocked
The empty pump has failed (you would usually expect to hear the pump rumming, but it may not be a noise that you are familiar with).
First and second items are easy to fix, the 3rd is a pump replacement, which isn't that hard, but depends on your level of DIY skill
Jun 23, 2011 | Washing Machines
I have a maytag neptune washer top load the washer stays in wash cycle and will not go to next cycle.
Clean out the pump. Ours was doing that as well, when our mechanic looked at it he could find nothing wrong with it so he looked at the pump and it was full of mud and junk. He said once it is cleaned out you have to run it twice a month empty to keep it clean. Ours has worked great since.
Apr 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
I just moved into a furnished apartment with a Hoover washer. Please could you explain how to operate it. I have used it twice, but both times it took at least 3 hours to complete the washing.
this is probably because most front load washer heat the water. check if you can adjust temperature or turn off,or check if the washer has a quick cycle for example quick 30 minute cycle.good luck keep me informed
Jun 22, 2010 | Hoover AAA160 Front Load Washer
Washer smelly musty and moldy. How can I get the smell to go away? Is there something we can take apart or clean to stop this smell. Not what you want to smell when you are trying to get fresh clean...
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Jan 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
HE4t washer leaves clothes smelling worse than when they went in. They come out smelling like clothes that have been sitting around for months. I suspect the cycle sequence is just draining the soap, but...
Aug 29, 2009 | Kenmore Elite 45986 Front Load Washer
Clean Cycle
I had the same problem. After unplugging and plugged it in several times, I got it to switch to a wash cycle. But now it beeps every 20 seconds.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
947 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
