Question about RCA 40" Class LCD 1080p Widescreen HDTV, 40LA45RQ
Wide would the picture go out on my new RCA TV
Only had it 2 months. With 1080p Full HD resolution, a high brightness level and a high contrast ratio, the RCA 40" Class 1080p Widescreen LCD HDTV delivers true high definition quality pictures. Multiple types of connection options give you flexibility and piano black finish improves its looks. Okay, this is a full detailed descriiption. I paid almost $400.00 for this. Is this something I can get to and fix, or do you think I can find an expert to come and fix it for me at a reasonable price? Please help me with this as I'm desperate.
    Sergeant:
  • 259 Answers
Contact RCA, apparently this model has problems.
https://www.youtube.com/watch?v=7w-Vc5CNYH8
Posted on Apr 30, 2017
Why rgb connection o.k. NO TV signal?
Check your manual for instructions to select video source. Also , please be aware that rgb video also usually requires separate audio connections along with the rgb.
Jun 08, 2014 | LG 32LK310 LCD HDTV, 32 Display Size, 16:9...
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Is the Sharp LC32D47UT 32-Inch LCD HDTV suitable for use in Australia
Quite possibly as it can cope with NTSC and PAL
The elegant AQUOS® LC-32D47UT easily enhances the decor of any family room, living room or den. With a 16:9 aspect ratio, HDTV resolution of 1366 x 768 and breathtaking color purity, it is a next-generation TV to carry you into the high-definition future. The LC-32D47UT features a high contrast ratio, 6ms response time and wide viewing angles. The LC-32D47UT includes built-in ATSC/QAM/NTSC tuners, 3 HDMI™ and 2 HD Component Video inputs as well as a D-sub, 15-pin input for PC compatibility. The LC-32D47UT features a black cabinet, and the included table stand easily removes for wall mounting applications.
Features
  • True 16:9 - widescreen aspect ratio with 1366 x 768 HDTV resolution.
  • Built-in ATSC/QAM/NTSC Tuners - provide access to DTV and available analog TV channels.
  • High Brightness - Sharp LCD TVs are very bright, so you can put them virtually anywhere - even near windows, doors or other light sources - and the picture is still vivid.
Jan 08, 2011 | Sharp 19 in. LCD HDTV
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How to change resolution on a Toshiba LCD TV from 480i to better?
Can't solve this problem, because I have the same one! I can say that adjusting some of the fine picture contrrols, like brightness, contrast, color etc help a little. This TV is supposed to go 720 and as high as 1080 I thought?..........
Mar 02, 2010 | Toshiba 32HL67 32 in. LCD Television
Loewe articos hd tv rear projection. contrast too shiny
Try lowering Brightness first.Not contrast leave it up middle range.
Dec 26, 2008 | Loewe Articos 55 55" Rear Projection...
52" RCA TV Plus color TV (12 years old)-picture is diminishing
Go into the menu and set contrast to full, bring brightness up to an appropriate level after.
Aug 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
JUST BOUGHT LG42LF66 FULL HD 1080P WOULD LIKE 2 KNOW BEST XD ENGINE SETTINGS AND COLOR,BRIGHTNESS,CONTRASR AND SHARPNESS SETTINGS THANKS J.SINGH
set my one like this:
picture mode=User1, contrast=60, Brightness=60, colour=30, sharpness=100, tint=standard setting.
colour temp.=cool, XD: contrast=off, colour=off, xdnr=high, mpeg nr=15.
Used gold plated scart for dvd & sky, picture looks pretty good, have not tried hd yet. Initial settings when first switched on were **** but with some tweaking have got good results.You probably have it set up pretty good now but just got mine & thought I would post this anyway.
Apr 23, 2008 | LG Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
RCA 40" Class LCD 1080p Widescreen HDTV, 40LA45RQ Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
