Question about Kodak EASYSHARE CD33 & Printer Dock Series 3 (Pack) Digital Camera
Ink cartridge won't come out of the printer
I am attempting to get the ink cartridge out of my printer and it it stuck
  • annieanne Jan 24, 2009
    I put a new cartridge in printer dock and it will only printed 3/4 of picture. The cartridge is stuck and cannot get it out and now the screen on camers say change cartridge. Any solutions???? Thanks
SOURCE: not recognizing new ink cartridge
We had the same problem and tried all steps Customer Service suggested each time; after several calls, it was determined we had a defective printhead... Kodak sent a new printhead, new ink cartridges w/ an envelope to return the ones I was using.
Apparently it's a common problem with this model; especially the earlier ones. Have had NO problems since the printhead was replaced.
I would suggest if you have recurring problems (even after Customer Service directives), call and ask if you might have a defective printhead.
Posted on Jan 16, 2008
  • 214 Answers
SOURCE: Kodax Eps-5 Printer want print with one cartridge
No you need functioning colour cart for black to work.
Posted on Apr 28, 2009
  • 3 Answers
SOURCE: ink cartredge stuck in printer
turn off printer hold down transfer button and left arrow button at the same. Then turn in Printer, you should hear it make some noises . Open the side push on cartridge to see that it is locked in tight. Hit the green "release" button and cartridge should come loose on its own.
Posted on May 18, 2009
  • 3 Answers
SOURCE: Can't remove used ink cartridge from G600 Printer dock???
I found a how to video on the web.Turn off your printer. Hold down the left arrow button and transfer button at the same time, then turn your printer back on. You should hear it make some noises, open side door push on cartridge to see that it is locked in. Then hit the green release button on the inside and the cartridge should come out on its own.
Posted on May 21, 2009
  • 9 Answers
SOURCE: Won't recognize color ink cartridge
This is a common problem with Kodak 5000 series and ESP series printers.
Check the silver contacts on the ink cartridges for small scratches in the center. The scratches indicate that the ink cartridges have made contact with the appropriate connections in the printer. If no marks are visible, the cartridge was not seated properly. If the contacts look ok, you'll have to call Kodak again. It's highly likely that the recertified printer you received was returned for the same problem. If you point out the fact that you are experiencing the same problem for the second time, you may wind up with an upgrade to an ESP5. Don't accept another printhead replacement as thiat will not resolve the problem.
Posted on Jul 17, 2009
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Ink cartridges won't move to the left, error code 6000
You will need a new carrage motor for this, better off with a we printer.
Jan 09, 2012 | Canon Pixma iP2600 Photo InkJet Printer
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
The check print cartridge light is on and won't go off even after changing both ink cartridges
This could be a number of problems. Depending on the printer and ink, you may have to power cycle it (turn it off and then back on after a minute). Many printers nowadays also have you do an alignment page. You may want to attempt to do an alignment page if your printer has that functionality built in. If that doesn't work, as silly as it sounds, check to make sure both ink cartridges are locked into place securely, even if you need to remove them and put them back in.
Aug 04, 2011 | Office Equipment & Supplies
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
My Lc61 will not print black--on the test page, the colors are fine. I've replaced the ink cartridge and it says it's full but won't print
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
May 26, 2011 | Brother Office Equipment & Supplies
My printer says ink absorber full is there anyway to reset counter
When you insert a refilled ink cartridge into your printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won't get the warnings again because the ink levels won't be monitored by the printer.
May 16, 2011 | Office Equipment & Supplies
Cant get my canon mx330 printer to work
Multifunction devices usually require two separate inks to acquire functionalities. For example, an empty ink cartridge especially the color ink may still produce copies without multi ink features. However, any attempts to dismaunt the ink cartridges would require restorations from the computer settings. First, inspect the printer for empty accessories that require replacements. After acquiring and replacing ink cartridges makes way for the next processes. Second, connecting the printer that has been restablished would produce display results requesting printer copy allignments. Attempt to print a document to produce the results for alligments. Goodluck
Jan 12, 2011 | Canon PIXMA MX330 Multifunction InkJet...
Cameras Logo
321 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
