Question about Mitsubishi VS-5077/78 TV
Mitswubishi VS-5077 TV - Display would work and flicker to black screen. We would wait awhile try again.....picture would work and then flicker and go to black screen. Now black screen w/ only volu
Been working on and off for 1 year
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
The most common issue here in the old sets is bad solder connections--the problem is you have to get the entire chassis free and up so bottom of boards face rear of set---look to power supply---a lot of 2 and 3 lead parts there from heat come loose from the boards and also to the middle of the set on the middle board.
If you are not able to attempt this the set is too old for a shop repair in my view as many parts for it are no longer available.
Posted on Nov 05, 2012
4 Suggested Answers
  • 135 Answers
SOURCE: Lose Picture
Hi there!
May be power supply related (old capacitors),dry joints on the main board or dry joints in the video amp section. Check for loose or bad connections. Good luck,JUS004
Posted on Feb 29, 2008
  • 1153 Answers
SOURCE: Front freznel lens cracked
vancebaldwin.com
Posted on Mar 26, 2008
maatmartin7
  • 1229 Answers
SOURCE: I have a Mitsubishi VS-5077 the screen has gone
You definitely have bad solder grounds. I have repaired a few of these. You will need a TV tech pull the boards out and resolder them. The worst board would be the one on the left [signal board, has rca jacks. rf connector]. And they may as well solder the second board. You will have a restored TV when completed. Thanks for asking and show a few hands of support!
Posted on Oct 10, 2010
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
No color
Confirm to me the brand and model number AND if you have not tried it=unplug the set for a while and then power up and see if that helps.
Mar 22, 2012 | Mitsubishi VS-5077/78 TV
I have a Mitsubishi VS-5077 the screen has gone black, it started out with the darker colors going green, I was having to boost the britenees, than a line would flash vert. across the screen, now no...
Oct 10, 2010 | Mitsubishi VS-5077/78 TV
Mitsubishi VS50707 - picture went out while TV was on. Sound still works. if i turn it off for awhile then back on, all three color tubes come on and flicker together for awhile before going out again....
The most common failure is the convergence IC's for what you are describing. They are large black flat-pack items mounted on aluminum, finned heatsinks. They will have numbers on them like STK392-110 or STK392-120. Yours may be different but most start with STK392-___. There may be some resistors that overheated and failed,... they are usually mounted near the IC's. They will be darkened towards the middle area. Google "Mitsubishi convergence repair kit" and you'll find suppliers who will sell you what you need , quite often with complete instructions. Here's the first one I found: http://www.tvrepairkits.com/xcart/home.php?cat=2638 This link is for your model number.
Aug 24, 2010 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Televison & Video Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
