Question about RCA F27664 27" TV
Removing parental lock on a ge/ modal num 46gw948
    Top Expert:
  • RCA Master
  • 14,553 Answers
I have never seen the 948 have parental control lock---it's too old for support from Thompson (GE/RCA) so I will ask a question: what precisely is the set doing or not doing? Does it have the "Guide Plus" logo on the front of the cabinet?
Posted on Nov 05, 2012
  • kevin mcgivney Nov 22, 2012
    yes guide plus on front when u go to a channel it says challel locked
I have fujitsu siemens amilo li 2727, Modal MS2228.Recently when i want to type uiopjklm,instead i get second commands like 456*123. u becomes 4,,i=5,O=6,p=*,j=1,k=2,L=3,m=0,etc.What is the cause and how...
hye bro, see its not a big problem, you must have to find a key with the name of (Num) at the keyboard. its means Num lock key. and the Second key is (Fn) at your key board. press and hold Fn key and then press Num key just once and then leave then,,, see now you keyboard broblem is solve. or simple Fn+F11 Fn key push and then F11 key..... when find you it a good tip then sey to me Thanks have a nice day imran pakistani
Feb 14, 2011 | Fujitsu Siemens KBPC SX Keyboard
Tip
Shortcuts you can use with Windows Explorer
Display the bottom of the active window. END
Display the top of the active window. HOME
Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)
Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)
Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)
Collapse current selection if it's expanded, or select parent folder. LEFT ARROW
Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW
on Apr 04, 2011 | Computers & Internet
Tip
Acessability shortcuts
Right SHIFT for eight seconds........ Switch FilterKeys on and off.
Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.
Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.
SHIFT....... five times Switch StickyKeys on and off.
NUM LOCK...... for five seconds Switch ToggleKeys on and off.
explorer shortcuts
END....... Display the bottom of the active window.
HOME....... Display the top of the active window.
NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.
NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.
NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.
LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.
RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.
Lost manual for GE 46GW948 tv
try looking it up online,and you can download it
Oct 19, 2009 | GE 46GW 948 46" Rear Projection Television
When i press o it comes up 6
You have activated the Num Pad. Look for the NumLk key , that is one of the function keys at the top of the keyboard, and disable numeric pad to get back to normal.
Sep 07, 2009 | Lenovo Keyboard
Ge projection tv
can you hear the tv starting on or a noise from the back
it may be the trippler or the power supply
Jun 14, 2008 | GE 46GW 948 46" Rear Projection Television
TV problem 46GW948 GE 48? Thomson Guide Plus GemStar
i hope this helps. on the tv, press menu, then channel up or down to "screen", then menu;
then channel up or down for adjust projection tv(6), then press menu;
then use the volume up and down, as well as the channel up and down until each of the 3 colors are lined up. press menu after each color i slined up to go to the next color.
hope this helps.
May 29, 2008 | Televison & Video
DVD parental lock
I have a GE 13TVR62 (with a problem listed here). I've learned that the Parental Lock Settings are changed by using the Remote Control. Usually the actual Settings are changed by pressing the Up or Down or Left or Right Arrows to make the Change; while the Parental Lock is Highlighted on the Menu.
Dec 22, 2007 | GE 13V110TD 13 in. TV/DVD Combo
GE 46GW948 42" flat Screen
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put off tv for 15 minutes & then put on again. do not move when it is on. please let me know if it gets ok or call tech to degauss it . it is hardly 5 minutes job. good luck
Oct 02, 2007 | GE 31GT660 TV
GE 46GW948
you should just need to go from the audio o/p of the tv. to the amp. now the tv will have either fixed or variable audio out. if fixed ok, if variable, you just need to know that the volume out of the jacks in the back is directly related to the volume of the tv, so you will need to keep the tv volume up a ways. now on the amp hook up to an available input, make sure that the input you use is set to recieve an analog signal. this is very important. every amp is different you may need to read the manual on how to adjust the input from analog/digital/audo. good luck.
Jan 08, 2007 | GE 46GW947 46" Rear Projection Television
RCA F27664 27" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
