Question about Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts
Installing hot water baseboard heater
I am installing hot water baseboard heaters and need to know how far off the floor these should be installed
  • 332 Answers
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Posted on May 29, 2009
  • gary miller
    gary miller Jul 17, 2009
    when you set the back cover in place there are rails in the cover to set the tubing in,, as for the backing cover set it on the floor
  • 24 Answers
At least 3 inches
Posted on Jan 24, 2010
    Problem Solver:
  • 12 Answers
Baseboard heaters can theoritically sit right on the floor, but are usually installed 1-3" off the floor to allow cleaning under them.
Posted on Sep 29, 2009
  • 103 Answers
I would do 4-6 inches ck your local building dept for legal codes...
Posted on Aug 09, 2009
  • patrick
    patrick Aug 09, 2009
    i would do 4-6 inches ck your local building dept for legal codes...
  • patrick
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
Why is my honeywell 8320r1003 short cycling for hot water heat.I have heat set at 65 degress.cycling 2min,3min,the most is 8min.
Hi Bill, after closing your thermostat, is this correct the situation?
And how far is your thermostat from your baseboard heater, if the baseboard is underneath the stat, you should move the stat elsewhere. Hope this help you find the problem.
Jan 03, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
We have a NELCO baseboard electrical heater, circa 1970s. We wish to remove it temporarily from the wall to permit new flooring installation under the heater. How are they attached to the wall?
It is attached with 2-screws or 2-nails. Depending on who installed it. I970's, I'm betting on 2-nails.
If you remove the cover, you will see where the nails are located on the inside back wall of the heater compartment and are attached to the baseboard. Be sure to turn the circuit breaker for the heater to the OFF position, be for attempting to unwire and move the heater. The circuit breaker should remain OFF until the heater is reinstalled.
Feb 28, 2011 | Fahrenheat FBE15002 Baseboard Heater
I am putting baseboard hot water heat in an older house that hase outlets in the way, is it alright to mount the baseboard above outlets . It would be about 12 inches.
Not sure that would pass code. But, you may want to check with the local building inspections dept in your area, before doing it. The other down side will be, the heat will start 12" of the floor rather than floor level. As you are aware, heat rises, so that would mean the lower 12" to the floor is going to remain cold. Want feel very good on bare feet that just jumped out of bed.
Feb 25, 2011 | Marley Electric Hydronic Baseboard Heater,...
New rad installation
Baseboard such as Slant-fin is made with a bracket that will allow you to run a 3/4" dia copper pipe back over the top of the finned area as a return pipe giving you a supply and a return on the same side. Both the finned pipe and the housing can be cut to any length and come in a 3' section from the factory.
Jan 20, 2010 | Marley Electric Hydronic Baseboard Heater,...
One zone not working; another is partly working
i would check my water pressure on boiler sounds like lack of pressure or air in system they can be related. if you have bleeder on baseboard try to bleed.
Feb 20, 2009 | Honeywell Programmable Thermostat Heater
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
Dec 01, 2008 | Marley Electric Hydronic Baseboard Heater,...
Baseboard heater connect
I have a fahrenheat F2548 baseboard heater, there were not any wiriing diagrams or installation instructions in the box where can I find the wiring diagram,
Aug 04, 2008 | Fahrenheat Electric Convector Baseboard...
Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts Logo
545 people viewed this question
Top Marley Heating & Cooling Experts
Paul Carew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
