Question about Cell Phones
Btck-18n not charging
Left on charge for 10hours,red light on,remove charge lead,no response from bluetooth product.Will be returning to supplier.
  • 21 Answers
Change your battery
Posted on Nov 04, 2012
3 Suggested Answers
ccrazeegyrl
  • 31 Answers
SOURCE: Removal of Battery Cover
have the newer I9 but same issue at first..but one answer is YES it should be red when charging. Next ques..My back was SO hard to get off i thought i was crazy at first. I had to use a sharp stek knife to CAREFULLY open it for the first 3-4 times but since that it opens and closes with ease but the first times it had to be pried open..but be careful--but eventually it will work just sliding it up and down.
Posted on Jan 13, 2009
  • 50 Answers
SOURCE: screen on phone is blank with white light, no
sir,you set software will be destorye,u install new software in the set
Posted on Dec 27, 2009
When I plug up the bluetooth to charge the red light appears then it blinks blue red does that mean it is charging or not because it is not working with phone
That might meaning that's it's draining the residual charge left on the battery, before it can be charged, but if it does this for more than an hour, your battery is "toast".
Aug 28, 2014 | Universal QuickCell Q7 Bluetooth Headset -...
Ilive bluetooth receiver/adapter won't turn on
Its a simple push button device , and if its not turning on . The product has stopped working and you can only return it back to the store or buy a new one...
Dec 26, 2013 | DPI iLive Bluetooth Receiver/Adapter
BT-38k will NOT charge. its new, just bought it 4 hours ago, and it wont charge up
Let the unit charge overnight to make sure that is the problem, if there is no change return the item for exchange.
May 21, 2011 | Just Wireless Bluetooth Headset Wireless...
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections...
Check this site to locate the controller for your scooter to determine what the lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Did you buy it new or secondhand? If it is new, it may be covered by warranty to have service done at no charge. Check your owner's manual for fault codes; contact the manufacturer if you are still having issues.
Oct 24, 2010 | Shoprider 889XLSN-BGRD-Enclosed Cabin...
My brand new madcatz bluetooth headset wont charge, when plugged in the charging light is red, but it increases/ decreases in brightness after 4 hours it will not turn on or sync. This is the second one...
i just got mine and it when i plug it in to charge the red light turns on for like 10 seconds then turns off and it wont turn on so itss dead... return it?
Aug 29, 2010 | Mad Catz Bluetooth Headset for PS3
Why does my avantalk BTCK 20 flash blue? if it flashes red that means it needs to be charged but why does it continually flash blue around every 3 seconds once I have it on? Looking forward to hearing a...
The bluetooth suppose to be a signal, and the posibility like the phone to activate it will often precising by the way that the bluetooth is running or working. For me, it is logic!
Mar 25, 2010 | Samsung Avantalk Wireless Bluetooth Visor...
When I plug my Motorola H710 bluetooth in to charge the light only blinks red and when I use it it never seems to turn on?!
Here's the instructions for charging.
Plug the Motorola charger into the end of
the headset.
The indicator light turns red when the battery is charging. It may take up to 1 minute for the indicator light to turn on. When the headset's battery is fully charged (about 2hours), the indicator light turns green.
From your information, it may very well be that the battery should be replaced if the red light doesn't go off as it should.
Here's a link to the full instructions. I hope this helps.
(Click here)
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H710%20QSG%20EN%20Generic.pdf
Feb 06, 2010 | Motorola Mobility H710 Bluetooth Headset
New jabra 350 can't be charged
right out of the box i had the light flicker on me too. if you don't have warranty or receipt like i did try this. i'm not responsible if it doesn't work after!
peel off the blue part of plastic that has jabra on it. take a screwdriver and unscrew the star screws. take the cover off. using some wires, briefly connect a battery (i used a wireless drill battery) to the leads of the bluetooth battery. you'll see a spark.
now my thing is charging for the first time
May 24, 2008 | Jabra BT350 Bluetooth Headset Headset
Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Nov 27, 2007 | LG Jabra A210 Bluetooth Adapter for...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
