Question about Shuttle Computer Computers & Internet
Pin assignments front panel IO - Shuttle Computer Computers & Internet
5 Suggested Answers
Rebgagnon
  • 382 Answers
SOURCE: FRONT PANEL PIN ASSIGNMENT
Here is the original manual in .pdf that will help you. Have a great day.
ftp://download.intel.com/support/motherboards/desktop/D845hv/hvwn_English.pdf
Posted on Feb 14, 2009
  • 5 Answers
SOURCE: i have the same problem!!!
Diagonally opposite to where you connect your mouse and keyboard, there will be pins for connecting front panel connectors. You can identify them by the names like SPK or Speaker written near them. You just have to match the front panel connectors with that of the pins. USB pins will be near these pins and will be labled as USB5 or USB4 on the motherboard. USB front panel connector can be inserted in only one direction.
Posted on Aug 23, 2009
djtatty
  • 417 Answers
SOURCE: front panel pin assignments for
try this mate.http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00281919/c00281919.pdf?jumpid=reg_R1002_USEN
if not you can bell me FREE & i'll talk you through it TEL:07970306952 (DAVE)
Posted on Sep 27, 2010
bayyagg
  • 1672 Answers
SOURCE: my front panel in motherboard broke i cant place
Don't get alarmed, if you still have the boards manual you can install the front panel pins and switches.
If you have no manual, go to this site and download the manual you needed, when you got there download the drivers update for newer versions of programs.
http://www.asrock.com/mb/manual.asp?Model=P4VM800
Thanks for using FixYa!
Posted on Jul 13, 2011
My DELL XPS dimension Gen 4 wont boot up. The amber light is steady and no diagnostic lights are lit on the back. The processor fan is going at maximum speed. Before this problem I could not plug in a...
The indications are of a NO POST. This can be caused by:
  1. Failed motherboard
  2. Failed Front IO Panel
  3. Damaged IO Panel Cable
If issues connecting USB connections occurred via the front connection, I'd suspect the IO panel as the issue. If the IO panel doesn't resolve, then motherboard is likely failure point.
Jun 27, 2011 | Dell Dimension XPS Gen 4 PC Desktop
Hi, im trying to connect motherboard intel D865GVHZ front panel to connection J9H3, i need a diagram for it. Thank you for your help
I may be confused with your problem you posted mar13974.
I thought Jumper J9H3 was for the Front Chassis Fan.
By your post, it leads me to believe you want the pin assignments for the Front Panel header on the mobo.
At any rate let's go to Intel Product Support, and the download page for the motherboard manual, for the Intel D865GVHZ desktop mobo,
(MOtherBOard),
http://www.intel.com/support/motherboards/desktop/d865gvhz/sb/CS-010872.htm
Click on the blue file name - D865GVHZ_ProductGuide01_English.pdf
After you click you may not see anything happening for up to 30 seconds. The file is downloading in the background.
(Took 16 seconds for me just now with a medium speed DSL connection)
Page 33 shows the location of the Front Panel header on the motherboard.
(C)
Page 34 details the pin assignments
Page 36 shows the Front Chassis Fan header location (Chassis front fan)
3-pin header, doesn't state the pin assignments.
With a 3-wire fan cable,
A) 1 wire is the Power wire. Generally Red
B) 1 wire is the Ground wire. Generally Black
C) 1 wire is the speed sensor wire. Reads how fast the fan is spinning in Revolutions Per Minute
(RPM) Generally Blue, but it's up to the individual manufacturer.
If the above isn't what you had in mind, please state in a Comment.
Regards,
joecoolvette
Oct 17, 2010 | Computers & Internet
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
When i turn my comp on the lights and fans start for about 1 or 2 secs then stops my make of comp is zoostorm
Pleease remove all connections (including Front Panel pin assignments) from Mother Board except Power Supply.
Now find out reset pin assignment on mother board and shot that pin if its woking then again do all connection and try.
other wise dismental complete system and re-assemble sytem. your problem will be solved
Mar 20, 2010 | Computers & Internet
I have the same problem!!!
Aug 14, 2009 | IBM (49P1599) Motherboard
DETAILED 34 PIN ASSIGNMENT FOR iNTEL se7520BD2
http://www.intel.com/support/motherboards/desktop/sb/CS-015851.htm
Jul 29, 2009 | Computers & Internet
Need the pin assignments for the mother board
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site (ASUS) to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | HP Compaq Presario SR1420nx...
My motherboard is a samsung harappa-30, pba: ba59-00905a rev: mp 1.1, help with front panel connection pin connection (hdd lights, reset etc.)
After you open the motherboard at the right hand opposite corner to the IO ports side( where we connect the monitor,keyboard mouse Etc ) you will find a set of 9 pins under which it will be written F_panel and P_sw,Hdd_led,P_led and reset pins and a no pin ie the the single pin
you have connect the front_panel wires in the order how it is named below and the black and white are negative ones so for everyu pair of connection + first and then - connect it in the order (13)(24)(57)(68)
+ 1 2 +
- 3 4 -
+ 5 6 -
+ 7 8 -
9(No connection Pin)
Apr 29, 2009 | Computers & Internet
HDD and reset light on intel p4 82845 mother board
Hi pc_ski,
Download the manual for your board, click on this PDF link.
http://download.intel.com/support/motherboards/desktop/D845GLLY/ADLY_English.pdf
See page 64 first for the layout of the front panel header. The block you need to refer to is letter C. Here you'll see where pin one is located at.
Go to page 65. Table 32 shows the pin assignments for the front panel header. Pin-1 & pin-2 is for the HDD & pin-7 & pin-8 for reset switch.
Have more questions? Post here.
Good luck pc_ski!
Mike
Mar 22, 2009 | Intel Desktop Board D845GLAD Motherboard
Feb 14, 2009 | Intel Desktop Board D845WN Motherboard
Computers & Internet Logo
18 people viewed this question
Top Shuttle Computer Computers & Internet Experts
David Payne
David Payne
Are you a Shuttle Computer Computer and Internet Expert? Answer questions, earn points and help others
