Question about Kenmore 72187 Air Conditioner
I have a coleman evcon mh unit and it is dripping water on the floor the pan appears to be rusted, any cheap fix
  • 70 Answers
If you can clean pan shine flash light through bottom try to see hole then use two part epoxy like jb weld to seal
Posted on Jan 04, 2009
Water is dripping into pan under fridge and overflowing onto floor. looks like water is dripping from filter at bottom. what can i do?
Check to see looks like the container is already full. You have to remove the tray full of water and then insert it again. It will happen again and again ( overflowing water) so you need to periodically check the container pan if water is full.
Also by checking periodically that pan, you will minimize rust build up. You will need to wipe around it with soft cloth or rags so the body of your refrigerator will not decaying due to rust built up. This will destroy the metal parts of the fridge.
Good luck.
Jun 25, 2011 | Kenmore Side by Side Refrigerator
My coleman rv ac unit is dripping condensation inside the camper, what is causing that?
It is possible that the drain hole on condensate pan is plugged and causing water to over flow pan. Remove cover from unit and check drain line.Clean coils andpan as best you can and clear drain hole. Add a small amount of bleach to water in drain pan.This will kill any algea or bacteria that may be growing in condensate water and plugging the drain. Thank you
Jun 20, 2011 | Coleman Mach III Air Conditioner
Water on the floor under the freezer side of unit
It happens to all those old refrigerators. There is a shield separating the drip container and freezer through a small hole. Check if it is blocked. This won't do much of the work and may not be stopped even if you do something. If you can, have a new refrigerator.
Apr 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Model 680 ss dripping on the leading edge behind
model 680 and up. the warer valve is located in the upper part of the unit. follow the water. is very posible the water is coming from the top of the unit. TIP. remove the upper grill. and a white cover. behin the white cover is the water valve.
Mar 27, 2010 | Sub-Zero 680 / F
Have a Coleman Evcon AH16W10BA dripping water from EVERYWHERE!
Probably the drain is clogh (it's a p.v.c. pipe , or could be a 3/4 or 1" hose comming out of the inside unit) , to clear the drain , the best thing is to blow air pressure thruogh it , and keep it clean by pouring about a cup of bleach every 3/4 months.
Sep 30, 2009 | Heating & Cooling
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
Puddles of water appear on the floor from the refrigerator every now and then why
if the water is coming from underneath unit then check to see if your drip pan is full. if so check your fan by your compressor. if not running there is not heat transfer to evap water out of pan.
Jun 21, 2009 | Refrigerators
Water leaking from coil pan that is cracked down center
Buy a new pan. Once they are broken they cannot be sealed due to the fact that they will not level out and will have problems with water going in other directions then to the train pipes
Jun 02, 2009 | Heating & Cooling
Coleman Evcon Heater drain tube backup
has to be clogged or frozen must get drain open or will shut down furnace
Dec 13, 2008 | Coleman Propane Forced Air Heater...
Kenmore 72187 Air Conditioner Logo
124 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
