Question about KitchenAid KCM511 Coffee Maker
KitchenAid KCM222 14-Cup Coffeemaker setting timer
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
https://www.youtube.com/watch?v=jEPf5hXWkB4
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Cuisinart.com
https://www.cuisinart.com/discontinued/coffee_makers/ss-1/ Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/ss-1.pdf Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using.
Amazon.com: Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ...
https://www.amazon.com/Cuisinart-SS-1-Matic-Coffeemaker.../B000RIAIXO Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at Amazon.com.
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ...
www.bedbathandbeyond.ca/store/product/cuisinart-reg-cup-o-matic.../1014760199 Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review
www.goodhousekeeping.com/.../cuisinart-cup-o-matic-single-serve-coffeemaker-881/ Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
Instruction manual for KitchenAid kcm11108
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kitchenaid model by clicking the link below.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kcm111ob_1.html
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 02, 2012 | KitchenAid JavaStudio 14-Cup Programmable...
I broke my 4 cup coffee pot to my red KA coffee maker and would like to replace it.
would need part # off the back or bottom of coffeemaker to look for correct part # for the 4 cup carafe.
Feb 14, 2010 | KitchenAid Coffee Makers & Espresso...
No brew, error 2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Jun 08, 2009 | KitchenAid JavaStudio 14-Cup Programmable...
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Would like to download an instruction manual for KITCHENAID COFFE
Manuals and exploded parts views are available for all Kitchenaid appliances at http://www.kitchenaid.com
Select "Customer Care" in the upper-right hand corner of the main page.
Select "Locate Manuals and Guides."
Type in your model number exactly as it appears on the bottom of the unit itself. The model number should appear on a white sticker, starting with "MOD: KCM" with additional characters to follow.
Mar 09, 2009 | KitchenAid JavaStudio 14-Cup Programmable...
Kitchenaid 14 cup programable kcm534er has an error code 4 what do i do
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Jul 04, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
Parts for Hamilton Beach BrewStation® 12 Cup Coffeemaker With Timer
http://forumappliances.com/images/Hamilton%20Beach/Hamilton%20Beach%20Parts/Hamilton%20Beach%20P-990021600.jpg
It's called a tank, not a pot. $9 CDN. Haven't been able to find in US yet. This is very hard to belive considering they make so many small appliances I think HB is not making parts available intentially to get consuners to buy again. Not sure this is smart.
Feb 12, 2008 | Hamilton Beach BrewStation 47224 Coffee...
KitchenAid KCM511 Coffee Maker Logo
134 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
