Question about Intel DP43TF Motherboard
CPU is not sending a video signal.
This started when reformatting a hard drive and installing an operating system on it (that's a separate problem that was fixed). This started once that was solved and everything was installed and loaded. Once I shut it off after that, it has not been sending a video signal to my monitor now. I thought it was hard drive, so I switched hard drives. I thought it was because of OS CD, so I took it out. I thought it was because CD/DVD-Rom drive, so I unplugged. I tried then unplugging everything for a while and replugging. I tried reseating everything and checking the connections. I tried switching monitors. I tried booting only the motherboard+video card + other essentials (no CD/DVD-drive or harddrive). I tried unseating one of my two RAM sticks. I also tried running it with just one of those sticks, then the other one. I tried the different settings for the motherboard of Normal/Configuration/Recovery. Nothing has been able to send out the video signal. Any help would be appreciated!
  • 5 more comments
  • Michael Nov 04, 2012
    While I was reading through the manual for the motherboard in hopes of discovering anything I may have bumped or missed, the video signal abruptly went through and the computer started loading.
    (^internet mess up, and don't see a button for delete/edit, sorry) I managed to install drivers for the graphics card and the motherboard, but then it auto-restarted... and I'm back to it not sending the video signal.
  • Michael Nov 05, 2012
    Just adding in things as I go along and try them out... tried switching out the PSU and booting solely the motherboard (main pin and 2x2 on this board), still no signal.
  • joecoolvette
    joecoolvette Nov 05, 2012
    Power unplugged from computer. Anti-Static Precautions FOLLOWED, remove all ram memory modules, and clean the gold plated contact pins on the bottom. BOTH sides.Although there are solid polymer capacitors on the motherboard, (Little aluminum 'cans' with Blue mark on top), there are also Electrolytic Capacitors on the motherboard. (Radial Aluminum Electrolytic Capacitors) See if there are any visual signs of failure,http://capacitorlab.com/visible-failures...
    There are no visible leaning, leaking, or bulging capacitators.
  • Michael Nov 08, 2012
    Gently rubbing the golden plated contacts on the RAM provides no change. Also for additional info, booting up without RAM yields 3 short beeps.
5 Suggested Answers
Vivekt1000
  • 35 Answers
SOURCE: motherboard will not boot up
Change the SMPS and try again.
Posted on Aug 11, 2007
  • 24 Answers
SOURCE: New motherboard will not boot
It appears that you are aware of Motherboard jumpers.
1. Reset BIOS settings by CMOS Clear jumper ( Location of jumber is given on the sticker / manual of motherboard )
2. Try updating BIOS of your motherboard from the following link :
http://downloadcenter.intel.com/Filter_Results.aspx?strOSs=All&strTypes=All&ProductID=2838&lang=eng&OSFullName=All%20Operating%20Systems
3. Plug only Optical Driver / Hard disk at a time and check.
4. Contact your vendor and get the motherboard replaced.
Posted on Feb 12, 2008
antiochpc
  • 1314 Answers
SOURCE: My computer turns on but nothing responds
Most likely your motherboard was DOA. Send it back for a replacement. Sounds like you've done all the troubleshooting stuff.....do double check the power supply connector...especially the P4 connector that I have occasionally forgotten to plug in...that will also cause the symptoms you describe.
Posted on Aug 14, 2009
bob_computer
  • 3153 Answers
SOURCE: jagged lines due to video driver/motherboard?!?!
If it works fine without a driver and only faults out when you apply the driver it would suggest that the driver you are using is incorrect. You may also be trying to start out with too high a resolution on your screen try lowering it before installing the driver.
Also ensure that you DO have the CORRECT driver
if yours has L75II8 on any labels underneath then go here to get the correct drivers
Also make sure you know which bios version you have as there were at least two Major revisions of this model and you may weel need to know to get the EXACT drivers
You might also want to update the bios for your revision if you can.
If this information was useful please click below
Posted on Aug 18, 2009
How to reformat pc hard drive?
Very simple, first take backup of all your Data on a Separate Hard Drive or CD, DVD, BluRay or Pen Drive etc. Afterwards, use your Operating System disk (that you're going to use after formatting), as you insert Operating System CD/DVD in your CD/DVD Drive, you'll get options out of which one would be suggesting you to format your Hard Disk, In Format Options, you'll get two sub options or even more, better and safe to choose default option (On which the cursor automatically sets before you choose, but if uncomfortable, call your Computer Service Center). As you hit that option, you'll find your Hard Drive getting formatted and after that, your computer will prompt you with Operating System Installation options.
And if you're about to format a Hard Drive, but not to setup an Operating System on it, even easier: After Backup of your data on that Hard Drive, just right click its icon and choose Format and you'll be able to do so after a few options.
Also, you can learn from Help and Support Section.
Apr 26, 2014 | HP Pavilion dv9925nr Notebook
Laptop shutdown while reformatting and now unable to bootup
If it shutdown while reformatting the hard drive, restart from a installer CD/DVD and reformat the hard drive before installing the operating system.
Apr 23, 2014 | Computers & Internet
Moving HDD from Dell Dimension 4300 to 4600 but b4 loading WinXP keeps going back to WinXp choice screen
haveu formmated your disk & installed an operating system ie Win7/Xp it seems u have not got an operating system.
Apr 25, 2012 | Dell Dimension 4600 PC Desktop
It keeps turning off on its own
I would do this: Start it in safe mode and perform a system restore back to the time it worked.
If this doesn't work, you'll have to boot from a system CD/DVD and do a Windows repair.
I think this is a software issue. But before you start reformatting your hard drive or something, open the computer up and disconnect everything but the CPU, memory, mouse, keyboard, and video. That will rule out the possibility of bad hardware.
Mar 05, 2012 | Medion Computers & Internet
Repair hard drive hey guys - i've had 2 500gb sata 2.5s fail, one was quite new and working fine externally, i formatted it and installed it on a customer's laptop (she left the charger out during...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
also you could use a linux operating sytsem 100% free
or you could buy a disk you can get one for around $4.50 "cheap" or download one
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
Ubuntu is a linux operating system which can repair hard drives widows have corrupted and cant be repaired by windows operating systems
Hope this helps you
Oct 27, 2011 | Computers & Internet
Asus eee pc 1005ha wont boot. Screen comes up to use repair or start normally. When go to repair windows loads files then begins to start then blank screen. No other activity. What to do?
Your operating system has a problem. The remedy in that particular problem is to reformat and re-install your operating system to avoid the Hard Disk or Hard Drive of your laptop to be damage.
If your laptop still suffer the same problem. Your Hard Drive maybe corrupted and need to replace with new Hard Drive...I always experience this kind of trouble to all laptop and desktop they bring to me for repair and those are solutions I posted here the ways to resolve the problem of your laptop...
If you don't know how to reformat your Hard Drive...see a computer technician to do it for you...If you have any other question regarding such trouble i am happy to answer all your questions
Sep 17, 2011 | ASUS Eee PC 1000HE Netbook
I need to know how to unintall all the data on my WD hard drive and start over again fresh. Can you help me?
Mac OS X
1 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
2 Open "Disk Utility," located in the Utilities sub-folder of the Applications folder.??
3 Select the drive you wish to reformat. Typically, drives appear twice; choose the furthest left.??
4 Click "Erase," and pull down the Format menu. Choose "FAT32." Enter a hard drive name, if desired.??
5 Click "Erase." A confirmation screen will appear, stating that all information on the drive will be lost if erased. Click "Erase." Once completed, the erased drive will function on both Windows and Macintosh systems.??
Windows
1 Download and install the Western Digital FAT32 Formatting Utility.??
2 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
3 Open the FAT32 Formatting Utility and select the desired external hard drive. Ensure that "Restore factory original FAT32 partition" is selected.??
4 Click "Start." A warning message will appear, stating that all data on the drive will be destroyed. Click "OK" to continue. Click "Yes"' to navigate through.?
May 03, 2011 | Computers & Internet
My computer was reformatted. i can't play any audio/ video materials in my computer.
That is part of reformatting. It erases all of the data that was on your hard drive. you will need to install a new operating system and reacquire your materials.
Mar 04, 2011 | Computers & Internet
The hard disks file system is corrupted.
If you can still access the PS3 menu, then reformat your hard drive by going to:
Settings > System Settings > Format Utility > Format Hard Disk
If you cannot, then you can try:
1) Remove the Hard drive, connect it to a PC and reformat it.
2) Download the latest PS3 operating system from the Playstation website and store it on a USB drive. Then insert the USB drive into the PS3 and start the PS3, and then install the operating system from the USB.
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
Audio glitches
When your CPU is staying at 100% run, that means you likely have gotten a virus or some serious spyware. Those can affect your audio and video playback, because some viiruses and spyware attach through your audio/video. try running your antivirys software; you can also try doing a system restore. if that does not work, you will probably have to reformat your hard drive and then do a fresh install of your operating system.
Sep 04, 2008 | Acer Aspire 1642ZWLMi Notebook
Intel DP43TF  Motherboard Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
