Question about Dryers
How to replace a dryer belt on a whirlpool model lhe 7800
My dryer comes on but the belt broke off so now it wont tumble how do i put another belt back on it?
Maytag317
  • 1136 Answers
SOURCE: Model LHE 6400- the dryer does not tumble but the
Normal 0 Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Posted on Jun 13, 2009
Maytag317
  • 1136 Answers
SOURCE: whirlpool dryer froze and wont tumble just makes noise where try
Hi, This dryser only has 1 belt. When you chacked the belt, was the belt located in the middle of the drum?
This model has an idler pulley that is no longer being used. They have went back to the roller style idler which is easier on the belt.
Raise the top and then remove the 2 screws holding the front to the cabinet. Remove the front cabinet and locate the idler next to the motor pulley. Look at the belt while you have the front off and see if there is any bad spots in it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 02, 2009
protek480
  • 1723 Answers
SOURCE: My dryer wont tumble
Your belt is not installed correctly. The weight of the clothes is making it slip.
aasc
  • 1606 Answers
SOURCE: Model # LHE 7800 W1 On the thermostat by the
On a/c voltage , if you have 2 terminals on a part , it won't matter which terminal the wire goes on . There are several red wires in that area ,so if it goes to the thermostat , it doesn't matter which terminal on the thermostat it goes on .
Posted on Jul 19, 2009
SOURCE: whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Posted on Jan 01, 2011
Dryer heats but doesn't tumble
Your belt either fell of or broke. Or the motor failed (There is a centrifugal switch on the side of the motor that may need love love or needs to be replaced)
Nov 30, 2013 | Whirlpool Dryers
Need repair manual for whirlpool LHE 4930 (old) to replace belt or find what other problem may be keeping the drum from turning
Type in Google search for the manual. if one exist it will be there. Just type in --manual for whirlpool LHE 4930 washer. 99.9 of anything printed is somewhere or can tell you where on Google search
May 31, 2012 | Whirlpool Dryers
Motor runs, but clothes tub will not spin, what is the problem? There is a vynyl looling inch belt on the tub.....tub spins freely with hand control.
either the belt slipped out of the idler pulley or the belt itself broke,, click on this link for easy instructions for your machine http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm please take a moment to rate my response Thanks good luck
May 30, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
Jan 09, 2010 | Whirlpool Dryers
Model # LHE 7800 W1 On the thermostat by the heating element Which terminal does the red wire go on?
Jul 13, 2009 | Whirlpool Dryers
Whirlpool dryer froze and wont tumble just makes noise where try
Vic
Jul 02, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool not blowing or tumbling
check to see if belt is still on drum. might have broke. thats the only thing that would cause the drum not to rotate but still should have air flow. the blower wheel is hooked up to the motor itself. your problem might be the motor itself has gone bad. if belt looks good then your motor is not turning.
Jun 22, 2009 | Whirlpool LER4634J Electric Dryer
Thanks
Vic
Jun 13, 2009 | Whirlpool LER7646E Dryer
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
