Question about Casio G-Shock GIEZ Series GS1100BR-1A watch
Problem setting time an hour earlier - Casio G-Shock GIEZ Series GS1100BR-1A watch
  • Casio Master
  • 18,394 Answers
Go here for manual > http://www.gshock.com/support/
Posted on Nov 05, 2012
THIS PRODUCT IS AN EVERFLOURISH TIMER. HOW CAN I ADJUST THE ACTUAL TIME ON THIS TIMER.
I suggest you email them direct for this and also for the manual at
efnb@everflourish.com.cn but it does sound like you have it and look at # 2, after setting the day, you set the time:
2. Time Setting 2.1 After setting the day of the week, hour display flashes to indicate setting time can be started 2.2 Press +Button to increase number of hour, or Button to reduce hour. 2.3 Press +/ Button once will increase or reduce each hour slowly. To press and hold the button, the hour display moves quickly. Release the button until your desired hour shown on the display. Press SET Button to confirm your setting. 2.4 “Minute” display then flashes to indicate setting minute is ready. Repeat the same procedures in setting hour as in #2.2 and #2.3 to set minutes.
manual here:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&sqi=2&ved=0ahUKEwii9O-RtrTMAhVKgiYKHRULDsgQFggjMAE&url=http%3A%2F%2Fproduktinfo.conrad.com%2Fdatenblaetter%2F600000-624999%2F616021-an-01-en-Mini_Zeitschaltuhr_digital.pdf&usg=AFQjCNGYADTAgA9msCpN4otTAxRQ1PJ6dA&bvm=bv.120853415,d.cWw
Apr 29, 2016 | Watches
I think i have an old one,but i have a two button illuminator watch. recently daylight savings began and im an hour ahead how do i change the time?
just reset the time as if the watch stopped
daylight time is not a special time just an hour earlier or later
Nov 08, 2015 | Casio Illuminator Watches
What time will greenville,tx be in Phoenix
it is one hour earlier in Phoenix. AZ than it is in Greenville, TX
Feb 01, 2015 | Watches
I have a casio g-shock GA100-1A1 and adjusting the analog settings isn't working at all? Their manual states to press A once you're done but its just goes back in reverse to an earlier time. What can I do?
click through to the world time and choose where you are, if the time isnt right where you are hold down the adjust and it should say dls and then make that say no and then manually config the time like hour n mins and then click mode or adjust again and it should reset, had mine not even a day, got it form a mate who was out afgan, its an awesome watch
Nov 09, 2010 | Casio G-Shock GW500A-1V Wrist Watch
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    Timex 1440 time from 24 hour clock to 12 hour
    Hi bowingman,
    To use 12- or 24-hour time for your watch, please follow the instructions below.
    1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
    2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
    3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
    4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
    5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
    6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
    Hope it helps.
    Thank you for using FixYa.
    Oct 09, 2009 | Timex 1440 Nylon watch
    How do you set the day/date on a watch????????
    Try this solution I posted earlier for a similar problem.
    Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time.
    If you pass 12:00 and there's no change continue rotating another 12 hours (to twelve o'clock again) and they should advance. Once you've found that there's midnight.So say it's now 4:00pm you would need to rotate the hands around the dial again so they pass 12:00 once more (12:00 midday) then four hours more to 4:00.
    To set the day/date you can set the crown (winder) to the first position (second posn is "set hands) and rotate winder
    eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
    Hope this solves your problem.
    Jul 17, 2009 | Seiko Wrist 5 SNKA03K1 Automatic...
    Set time on Touch Screen Thermo Clock
    Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
    1. To set the time, touch the clock icon on the upper left corner;
    2. Keep touching the screen for longer than 5 seconds, on the hour area;
    3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
    4. Touch the clock icon again to start the clock;
    5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
    6. To set the date, tocuh the calendar icon on the left hand side;
    7. Keep touching the screen for longer than 5 seconds, on the year area;
    8. Touch the year area until you get what you want;
    9. Touch the month area until you get what you want;
    10. Touch the day area until you get what you want;
    11. The screen will reverse to the time display after 5 seconds if no touch.
    12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
    P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
    Hope it helped.
    May 08, 2009 | Watches
    Casio G-Shock GIEZ Series GS1100BR-1A watch Logo
    78 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
