Question about Yamaha Aw4416 Aw 4416 Workstation
I have a Yamaha AW4416 Work Station. I get sound when playing CD's but when I play my recordings they register on the input channels but won't play through the stereo channel. What do I do?
I get no sound out of the stereo channel when playing my recordings. I only get sound when playing CD's.
  • 120 Answers
SOURCE: Electric Guitar wont play through Amp
the buzzing is indicative of an open ground connection, check the cord by substitution or with an ohm meter, if the cord is good look at the connections to the jack inside the amp ( im guessing you built the amp from a kit). Is this a solid state amplifier? Tube amps have lethal votages and should not be experimented on without knowledge of electronic safety. Also if there is more than one input to the amp try plugging the guitar into another one and see if its still the same.
Posted on Jan 02, 2009
  • 1138 Answers
SOURCE: recorded midi, output set to dtxpress channel 10 no sounds is gen
You have to discover the receive channel for the dtxpress. Try downloading Midiox which is a freeware app that actively displays everything that is happening midiwise in real time.
Posted on Aug 28, 2009
  • 5603 Answers
SOURCE: I have a Yamaha AW4416 recording deck.Tracks 14,15
Is there possibly a write protect or lockout feature?
Posted on Oct 14, 2009
  • 5603 Answers
SOURCE: When I route either the
Make sure you use BALANCED TRS audio INTERCONNECT cables.
Posted on Dec 16, 2010
Testimonial: "Thanks! I appreciate your input. That makes sense. "
jdvillanueva
  • 2098 Answers
SOURCE: I have a yamaha Emx312sc
Hi lholton,
This symptom indicated that you have a faulty OpAmp IC in the Mix circuit board. The IC's involved is the NJM2068M-D and NJM4558M-D. If I'm not mistaken you have more than 15pcs of this IC's in the circuit board that control the mics inputs. This is a 8-pin IC in D package. You must have at least 2 good IC's spare if you are going to DIY to swap or compare the reading of each IC's in the board.
Also, bad solder joints must be consider in that board and in the power supply feeding this board. Check it first, this is hard to spot, I would advice you to work in the brightest area or used table/portable lamp and magnifying glass. Re-solder as much as possible.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 09, 2011
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
Factory reset for the yamaha aw4416 workstation
The original factory settings of the AW4416 can be restored by recalling Scene Memory '00'.
1) Press the [SCENE] button in the 'AUTOMATION' section.
2) Press the [F1] button to display the 'Scene Mem' page.
3) Turn the (DATA/JOG) dial to select '00.Initial Data' on the screen.
4) Press the yellow [ENTER] button.
Reference: Operation Guide, p. 203
Sep 09, 2012 | Yamaha Aw4416 Aw 4416 Workstation
When i put in the blank cd i record but when played back no sound on cd.not recording
A common probllem with stand-alone CD recordders is that one MUST do a "finalize" operation before the disk will play on most CD players.
Feb 23, 2012 | Tascam CC 222MKIII Professional...
I have my Onyx Blackjack plugged into my computer but the sound is only playing and recording through the left channel, with or without headphones. Is there anyway I can fix this?
You haven't told us where the "sound" is coming from... If you are ONLY plugged in one channel that is all that will be recorded. We can't guess at how you are setup. Please provide an adequate description. If you only have a mono signal to start with, then get a WYE connector and jumper to the second channel.
Sep 05, 2011 | Mackie Onyx Blackjack 2x2 Recording...
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Recorded midi, output set to dtxpress channel 10 no sounds is gen
Aug 26, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
My acoustic guitar sounds choppy when played back.
Try Using A Condenser Mic Or Making Sure That Your Phantom Power Is Turned Off When Using A Regular Mic.\www.Myspace.com/CrossRoadsToNowhere2007
Nov 06, 2008 | Boss Micro BR Digital Recorder
Yamaha Aw4416 Aw 4416 Workstation Logo
46 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
