Question about Pride Mobility Pride TSS300 Power Chair - Used Electric Wheelchairs
Scooter not used while in nursing home now batteries wont charge
Batteries completely dead wont charge
    New Friend:
  • 9 Answers
Try new batteries, how old are the originals?
Posted on Feb 04, 2013
  • Jeff Tilburn
    Jeff Tilburn Mar 06, 2016
    I agree buy new batteries when u don't charge them for a while they form a coating over the cells when this happens they will not accept a charge,.cheers
Batteries ran completely down now fully charged scooter wont work.
hi if youre batteries have been sitting for 18 months without a charge they r probably no good now after batteries sit for a long time the plates develop a coating & when u do charge them the they will not charge properly..youre charger guage is not a true reading the only way Is to use a battery LOAD tester this will give u a true reading on the condition of youre batteries...u can buy a battery load tester of e/bay for aprox $35 ........
Sep 06, 2015 | Golden Technologies Companion II Travel...
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
I turn on my razor E300 the lights comes on to say its on but dont work i plug my charger in and on the chager the green light comes on saying its full charged what could b the prblem ?
The green light will come on if the charger does not sense a low battery. In other words, if you plug it into the wall, and not the scooter, it will still show the green light. It will only show a low charge (and charge the battery) if it is completely connected completing the circuit. My guess is that the battery is dead, and the plug is not all the way connected. Also, I believe the scooter has to be turned off to charge.
Oct 18, 2014 | Razor E300 Scooter
Why dose my battery charger start for a second and click of
Could be scooter battery voltage is too low for charger to charge battery.
(It is a problem with gel cell batteries I have got a scooter that won't charge at all at home am going to try jump starting with another battery to fool the charger but I might have to buy new batteries.The Nursing homestaff took the scooter off my father in law and left it in the shed to get nice and flat instead of leaving it on float charge I should send them a bill for new batteries
Sep 16, 2014 | Health & Beauty
Why won't my lights work
It sounds like your alternator is not charging the battery. Fit a new battery remember to undo negative lead first to remove and fit positive lead first to refit the battery. When the new battery is filled please charge it using less than 1 Amp DO NOT use a car charger or try to jump start it. Your new battery should show 12.5 to 13 volts on a meter for a 12 volt system and 6.3 to near 7 volts for a 6 volt system. Start the scooter and check across the battery terminals your meter should show about 14.4 V for 12 volt battery and about 7.5 V for a 6 Volt one. No voltage increase means your charging circuit is not working. Either the alternator or rectifier(regulator) are not operating correctly. Worst case scenario is both units dead.
Sep 06, 2014 | 2012 Piaggio Fly 50 4V
Scooter won't start
hi, so has the fuse blown again ???
Regards
Rob
www.gewizrepairs.co.uk
Mar 11, 2014 | Pride Go Go Elite Traveller Plus HD 4...
I have a tss300 powerchair it wont charge
I brought the TSS300 home put the seat back on the drive portion, reconnected it and nothing works, lights don't come on key button don't work and won't charge, everything is just dead. Checked Battery voltage and it is good. What can I do ?
Mar 10, 2013 | Pride Mobility Pride TSS300 Power Chair -...
My Dad just passed away and his Dr. K Phantom 3 wheel scooter won't run. When I plug the charger in, it says its fully charged. When I unplug it..it reads E..I want to donate this to a nursing home locally...
tar the batteries are probably too low to charge with the scooter charger and need to be replaced. With the charger plugged in it will indicate a full charge beacuse its reading the output of the charger but when you unplug it the batteries are too low to indicate any voltage. hope this helps you
Apr 10, 2011 | Drive Medical Mini Phantom Three Wheel...
My scooter wont charge. Light stays red for days of continuous charge. wont run at all. only nine months old.
Sounds like the batteries are dead.
Nine month is reasonable depending on how the batteries are use considering they are lead-acid batteries.
Lead-acid batteries get PERMANENTLY damaged when you drain them all the way. It would be better for the batteries if you only used them half way can charge as soon as possible after each and every run. They like to be kept fully charged at all times.
Sep 06, 2010 | Razor E300 Scooter
Pride Mobility Pride TSS300 Power Chair - Used Electric Wheelchairs Logo
299 people viewed this question
Top Pride Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Scooter Doctor
Scooter Doctor
Are you a Pride Mobility Health and Beauty Expert? Answer questions, earn points and help others
