Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Ws-55813 mod. green ld light wont stop blink tv wont turn on
Even when reset button is pressed
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Posted on Jan 05, 2009
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Mitsubishi Model 65713 - Timer Button Light Blinking-TV Won't Power On
open the back with the unit unplugged and see if any of the fuses are blown. if not the home service and let the tech decide if it should go into the shop
Dec 05, 2007 | Mitsubishi WS-55813 55" Rear Projection...
BLINKING GREEN LIGHTS IN FRONT
Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030..if they are ok then the DM pcb itself is bad part # 934C067002
Nov 27, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Timer light
does the light blink for more than 70 secounds? if it does go off after 70 seounds the keyboard lockout feature may be engages to unlock press and hold menu on keyboard for 10 secounds. If the set contiunes to blink after 70 secound after plug in then you maye have power issues or a possible bad digital board
Nov 04, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Timer Light Blinking
Replace four caps in DM module 1000mf/25v 105 degree...
common repair for qualified Mits tech............T.
Oct 13, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
