Question about GE Refrigerator Freezer Door Gasket - WR24X10056
Moisture on top of freezer near door - GE Refrigerator Freezer Door Gasket - WR24X10056
    Problem Solver:
  • 20 Answers
Change gasket or adjust door to assure a good seal.
Posted on Dec 05, 2013
I have a Frigidaire freezer that is about 5 years old. I get ice build up inside the top of the door. The door appears to be closed.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) Due you have the freezer in your garage? Freezers and refrigerators are not designed for the drastic temperature change through the seasons. If you had a service contract, your contract would be canceled.
2.) If you can run a piece of paper between the top door gasket and the freezer body you do not have a tight seal. Repair - Recondition the gasket. Wet the door gasket with water, with a hairy dryer heat the gasket while genteelly pulling the gasket out to expand with a spatula.
3.) If the gasket is good, then you are getting moisture either thru the top front of the unit or the top of the door.
a.) Inspect the liner where the ice build-up is. Are there cracks? Repair - Seal cracks with a good silicone adhesive.
b.) Inspect the upper door section and the front top of the freezer for possible leaks in the joints. Here again seal with adhesive.
c.) If the top of the door is expanded, then you have moisture in the door and need to replace the door. You will never get the moisture out of the insulating material.
Feb 12, 2015 | Frigidaire Freezers
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a very noisy fridgidare upright freezer causing snow on contents inside it?
Hi Lisa, thank you for your post! New freezers retain colder temperatures. Especially on hot humid days, moisture entering the freezer (when the door is opened) can form frost inside the appliance and moisture collection inside the unit. Reducing energy use to meet government requirements, defrost heaters have shorter run times. Light loads in the freezer also contribute to the problem.
Here are some tips to keep moisture low in the freezer:
Use your air conditioner to reduce humidity.
Arrange shelving and food items so air circulates.
Don't "overload" or leave the freezer empty. It should be at least half full.
Set the controls as recommended in the use and care guide. Manufacturers may suggest different settings for summer and winter.
Properly seal liquids and high moisture foods stored in the unit.
Open the freezer doors as few times as possible.
Clean condenser coils at least twice a year. Check your use and care manual for specific procedures. You'll save energy, too.
Cover pots and pans and use the range hood fan when cooking to reduce moisture in the kitchen.
Check and maintain door gaskets. A good door seal keeps warm moist air out of the freezer.
These tips will help control frost and moisture in your freezer, but won't always eliminate the problem, especially when humidity is excessive. If you have taken all necessary steps to prevent moisture and humidity, you may need to reach out to a professional for further diagnosis.
Hope this information helps resolve this issue.
Aug 22, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have condensation coming off the refrigernt tube that runs from condenser to freezer also ice build up on inside to the point of tearing the metal on inside back panel. What causes this ?
A side door heater is already defective.
It has heating element, it is there to dry any moisture build up around freezer door.
When it become defective, moisture or condensation occur, hence moisture is there.
Causing it to rust build or develope on the metal of the freezer.
Rust weaken the metal and soon tearing it.
Have it check by a service technician before it getting worse.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Iced up copper pipe... both fans in freezer are not running anymore.. The freezer is a 3 door commercial unit. I had someone here today to fix leak and add Freon. It was working great but when i came to...
Call back who ever fixed the leak, you still have one.
After fixing the leak make sure the drier is changed, system evacuated to at least 500 microns, then do a standing test. Meaning let the unit stand with the micron gauge connected. The unit should hold a vacuum. A slow rise indicates moisture, whereas a rapid rise indicates a leak.
Feb 03, 2011 | Freezers
Freezer door "locks" or is hard to open, if opened a few minutes prior?
This is normal. Freezers have a vent port to let high moisture out. When you open the door moisture laden air enters. When the door is closed the hot air from outside expands and leaves through the vent port. This creates a vacuum in the freezer that lasts a few minutes. No problem
Sep 16, 2010 | Sub-Zero Freezers
Left my upright freezer open a crack and now the
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
May 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
I have 15 year old Kenmore upright freezer -- NOT frost-free model. Recently have found ice buildup at top of freezer ---which returned within days of defrosting. Will replacing gasket solve this ? ?
depends on what condition it is in in most cases yes as long as the doors and body are in good shape meaning doors not loose and hanging or holes or dings in the body to allow air and moisture to get in
Jul 20, 2009 | Freezers
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE Refrigerator Freezer Door Gasket - WR24X10056 Logo
47 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
