Question about Pass & Seymour Electrical Supplies
Need a wiring diagram for pass & seymour self contained rocker wall switch
electrodynam
  • 35 Answers
SOURCE: Revised question for three rocker switch.
Posted on May 22, 2009
  • 351 Answers
SOURCE: need wiring diagram live cable from switch to pull switch then to
If I am understanding you correctly .,. then like this ..
Please Vote !!
Posted on May 13, 2010
SOURCE: pass and seymour ws 3000 Hooking up to basement I
You're right, green goes to ground.
Black wire connects to Hot wire from breaker box
Red goes to Load (fan, light, motor)
Ok which wire on the switch goes to the Load?
And which goes to Hot from breaker box?
You can test or you can simply hook up the device. If it doesn't work, swap the two wires.
It just won't work until the 2 wires are correct.
Posted on Oct 24, 2010
SOURCE: I am using a Pass & Seymour illuminated three
I answer questions for free
I work with timers and electrical devices.
If I understand correctly you replaced a 3-way switch.
The new switch has 3 screws (plus green ground screw)
You put the Hot wire on the dark screw correctly.
You attached the two travelers to the brass-colored screws.
The two travelers are red and white.
You connected the ground wire to the green screw.
The ground wire is not supposed to be connected to with the white wire, and I doubt it is because that would trip the breaker.
The lights are working correctly.
If you followed the formula above to the letter, then the lighted switch should light up.
My best guess at this point is that the lighted switch is defective.
The Pass and Seymour webpage does not have manuals to look at like Leviton and Lutron products.
As a result I can't pour over a manual and put a magnifying glass on the wiring and wording to see if there is something we've missed.
But it's just not that complicated ... the light switch should light up.
At this point, I suggest you re-read the instructions (just in case?) and then swap the switch for another one ... or get different brand.
Posted on Nov 04, 2010
SOURCE: How to install Pass & Seymour 5410CC10 sp2
The cord that runs to your light contains two wires.
The cord switch interrupts one wire.
The second wire runs uninterrupted between wall plug and light.
The photo below is not the same switch as yours, but it shows how one wire is interrupted and the other wire is uninterrupted.
Which wire do you want to interrupt?
Look at the wall plug.
Is the plug polarized, where one blade of the plug is wider?
If the plug is polarized, then one blade is wide and the other is narrower.
Each blade of the plug feeds one of the two wires going to lamp.
Locate the narrower blade, and the wire that comes from that side of plug.
The narrow-blade wire is the wire you want to interrupt when installing the cord switch.
If the plug is not polarized, then choose one wire.
Posted on Nov 09, 2010
How do I wire a Pass & Seymour legrand 885-TRNICC12 electric outlet
Hot wire to brass-colored screw
Neutral to silver colored screw
http://waterheatertimer.org/Basic-house-wiring.html#test
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 30, 2014 | Pass & Seymour Electrical Supplies
I need a wiring diagram for two switches and one light
I f you intend to run one light with two switches you should opt for 3 way switches. the wiring diagram is usually inside the box if you by them boxed.
Mar 08, 2014 | Pass & Seymour / Legrand 1595-2SWT...
Vanity cabinet with lights needs power
Dimmer wires in series on either wire of the cord.
Nov 27, 2013 | Pass & Seymour Pass Seymour 90611WV 600W...
How to wire a pass & seymore 692 switch
Wiring diagram located at
https://www.legrand.us/passandseymour/light-switches/combination/led-lights/692ig.aspx
Jan 29, 2013 | Pass & Seymour #692LAGCC6 15A Almond SP...
How to install Pass & Seymour 5410CC10 sp2 cord switch on a torchiere lamp? Can it be used the same as an sp1 switch?
Nov 08, 2010 | Pass & Seymour 5410CC10 Black Feed Cord...
Don't know how to fit the wire into the inside of the switch
Since there are only 2 wires, it doesn't matter which wire goes where. Either way it will work.
Apr 26, 2010 | Pass & Seymour #5410WBPCC5 White In Line...
I bought a Dual fan and light control SLSDC16WCC6, no instructions in the box. The unit has red, black, yellow, and green wires. The electrical box for the wall switch has three wires, orange black and...
Would suggest you contact the Pass and Seymour Div. of Legrand (France) and ask for the pdf file with the instructions. Your unit has a wireless function and must be work properly.
Sep 02, 2017 | Pass & Seymour CS320LACC 3-WAY COMMERCIAL...
Electrical Supplies Logo
318 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
Mike Squire
Mike
Gil Shultz
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
