Question about Jandy Air Energy Heat Pump - 100,000 Btus
Fault Low Flo Pressure
I am getting an error code for the Jandy remote "Fault Low REF Pressure
    Top Expert:
  • Jandy Master
  • 5,922 Answers
Check pressure switch and copper tube to it
Posted on May 02, 2015
3 Suggested Answers
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 246 Answers
SOURCE: How to fox flo 6 problem on Jandy lite2 175n pool heater
possible was the wron one I assume was the same one clean the filter clean the basket check for clog impeller
Posted on Sep 02, 2009
LAARS LX250N-L error code AIR FLO SW and sometimes a HI LIM SW cannot locate the source of the problem?
hi limits are located under where the pipes go into the heater if corroded replace if wires bad replace to test you can jump them at the board only testing if left jumped heater could catch fire
Jun 29, 2015 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Fl0 code
Flo ? for Flow Error?
That would for any number of reasons that the Flow Switch is not sensing enough water flow to trip the sensor/pressure switch or actual true water flow switch.
Heater will not run or heat, if there is not enough water flowing!
The heater will sense this. So, whatever will restrict or stop sufficient water flow is the problem.
  • Dirty filter
  • Closed valves
  • Not enough water in tub or pool - low water level
  • Clogged pump impeller
  • Clogged baskets:
    • at pump or at skimmers
  • Clog / stopped up plumbing line
And finally, you may have a bad flow switch/sensor
Sep 06, 2014 | Jandy Pool & Spa
Fault low ref pressure. how do i fix this?
check to see if filters are clean if so check to see if voltage on both sides of pressure switch if not either need new pressure switch or copper line is plugged
Nov 28, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
How to do back pressure test on pool heater
FLO is an open circuit error. you have several other safeties other than your pressure switch
Sep 01, 2012 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Low ref pressure
check filteres if clean check pressure switch voltage both sides should be 24 volts
May 18, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Heat pump low ref pressure
ee if filters are clean then check pressure switch to see if voltage on both sides should be 24 volts ac if not pressure switch bad or copper line plugged
Apr 02, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Jandy AE.TI AE3000T .263 BOARD SHOW FAULT SHORTED H20 SENSOR
The H20 sensor is the Pressure Switch. Locate the pressure switch, remove the two leads and jump them together. If the error code goes away, you need a new switch. If not, it could be a software, or other hardware issue.
Jan 08, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Heater will not light off
Be sure filter not dirty or too old lack of flo can cause tripping of high heat switch check flo switch also always check simple things 1st traceace
Dec 20, 2008 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Jandy Air Energy Heat Pump - 100,000 Btus Logo
74 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
