Question about Plumbing
Maax neo round stall leaks where base meets wall
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Many times there are small cracks in the panel or the base. It may not be able to be seen until someone is standing in the shower.
Posted on Jan 22, 2013
2 Suggested Answers
Asbestos 56
  • 191 Answers
SOURCE: I had just bought a
Depending on your level of skill and desire to have an invisible repair you have a few options. From easiest and worst looking to harder/expensive Use a marine epoxy, like marine tex or super mend. This could look Ok depending on your skill you can get an acrylic/fiberglass repair kit. or you could get someone who fixes hot tubs and bath fixtures to do it
and hire a better class of drywallers :)
Posted on Aug 11, 2011
I have a Maax Neo-Round Corner shower that leaks under the track the doors slide on. I have caulked inside & out but still leaks. Any suggestions????
You may have to remove the doors and the track and reinstall the track on top of a "bed" of caulk or sealant to prevent migration of moisture underneath. The leakage also may be caused by moisture running down the inside of the doors during active showering. Check also for warpage in the track that would cause it to seal unevenly
Nov 10, 2012 | 2003 GMC Envoy
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
Maax neo round shower stall continues to leak at bottom where it meets wall. Keep recaulking. Same results.
Many times there are small cracks on the material, it can be hard to see but opens up when someone is in the shower.
Nov 04, 2012 | Plumbing
I had just bought a neo round 32 inch acrylic shower base and had a plumber install the base.. Unfortunately, while installing some drywall in the bathroom, one of the installers managed to create a small...
Aug 11, 2011 | Maax Acrylic Base for Shower - 102623
Trying to install a Maxx Neo-angle corner shower with prefab plastic base. No description as to how to affix the base to wall (no holes or tabs to screw into the studs)... Only instruction is...
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Dec 14, 2010 | Maax Acrylic Base for Shower - 102623
Does the styrofoam liner stay in the base of the round shower base?
If it fits flush under unit, yes, leave it there. It helps as a structural support for the floor.
It it stick out at all take it out as it is just packing material.
Hope that helps.
Feb 09, 2010 | Maax Breeze: Two Piece Round Shower Module...
Hi we just bought a maax breeze neo corner shower how do i install the two back walls do you use glue or what?
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
Nov 19, 2009 | Maax Breeze: Two Piece Round Shower Module...
Plumbing Logo
132 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
