Question about Toys
Dorel replacement charger 6 volt - Toys
2 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: 12 volt replacement battery Dorel
I'd like to bring your attention to a CPSP (U.S. Consumer Product Safety Commission) recall on the battery for this item. http://www.cpsc.gov/cpscpub/prerel/prhtml06/06018.html So it looks like the battery is on the company itself this time. But just in case here is the link for the new battery itself http://www.safety1st.com/usa/eng/Products/Play-Relax/Toys/Details/2699-50800-Ride-On-Battery
  • Hazard: An electronic malfunction can occur in the ride-on vehicle's circuit board and/or battery connector, resulting in smoking and melting of components. This poses a vehicle fire hazard and a burn hazard to consumers if components are touched while malfunctioning.
  • Remedy: Consumers should take the recalled ride-on vehicles away from children immediately and contact the company for a free repair.
  • Consumer Contact: For additional information, contact Dorel Juvenile Group's Ride-On hotline toll-free at (866) 611-3022 between 8 a.m. and 4:30 p.m. ET Monday through Friday, or visit http://www.djgusa.com/usa/eng/
Regards, Tony
Posted on Apr 21, 2011
My yamaha cygnus battery needs recharging everyday I have replaced the battery for the 3rd time in 6 months without success.Everything else seems to work just the battery issue any suggestions please
take it to a yamaha service center and have them check the voltage output of the charger system
if it chargers more than the 14.5 volts for a 12 volt battery or more than 8 volts for a 6 volt battery , that will explain the causes of rapid battery failure
Nov 28, 2015 | 2006 Yamaha CygnusX
Do I have a battery or charger problem.?
I would, first, suspect the battery. The fix is easy: get a new battery. If it takes the initial charge, you have your answer, and shuld buy another battery. If not, replace the charger.
Since the odds are the battery is at fault, you're back in business. If not the battery, a new charger gets it done. Main thing, you needed two batteries ennyhoo, so if the battery change works, you're where you shoud'a been in the first place. mw
Apr 04, 2015 | Drills
Crossed poles on starter changing oil filter, starter only clicks one time wont start
very vague info. but possiably 2 issues, 1, shorted battery, remove neg. terminal clamp, recharge with 12 volt charger if it is 12volt , 6 caps= 12volt. 3 caps = 6 volt , look under caps for the number of cells. use appropriate charger. 2 ,starter solonid may need renewel, replace starter. Solonid may be independent of starter, if so replace solonid. Just a guess, maybe a blown fuse also.
Feb 14, 2015 | Cars & Trucks
Can u use a 12 volt charger to charge a 6 volt spot light 1000,000 candle power s800g
obviously not as the 12 volt will fry anything 6 volt. It is like putting 240 volt into 110 volt and wondering why it blew up. Get the right charger for the unit and save yourself heartache and money
Aug 12, 2013 | Camping, Backpacking & Hiking
Peg perego 6 volt battery charger light wont come on
check it with a multimeter and see if its putting out any voltage, specifically 7.2 volts, it could be just that the led is bad on the charger but its still charging
Aug 05, 2012 | Peg Perego - 6 Volt Battery Charger...
How do u charge a edelbrock power wheel corvette for kids 12 volt batteries and a 6 volt charger
Hello! Due to Charger Voltage Compatibility: Never use a battery charger unless the battery voltage matches the output voltage rating of the charger...Therefore do not use a 6-volt charger on a 12-volt battery and visa-versa...
guru...........
saailer
Sep 27, 2011 | Cars & Trucks
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
Charger is putting out 13.7 volts but battery does not take a charge
If its the right charger, and connected correctly, then it is probably just time to replace the battery. Try checking out http://www.batteryinternational.com/flashlight-batteries-streamlite---maglite.html for a replacement flashlight battery. Also, I'm not sure exactly what you mean by saying the charger is putting out 13.7 volts, but make sure you aren't using a charger that is too powerful, that can destroy the battery. Check out http://www.batteryinternational.com/battery-chargers-6-volt-battery-chargers.html. You shouldn't use a charger any larger than that. Hope that helps
Jul 10, 2009 | Vector 3 Million Candlepower Rechargeable...
Laptop freeze when in ac charger
You really should have a cheap multimeter to help in this case.
There are three possible failures; the new battery pack has a shorted cell, the charger is defective or a regulator internal to the laptop is failing.
With meter, you can check two of the three areas; the battery pack and the charger. Depending on which kind of batteries are used in the pack, if it is charged, you can determine if it is completely functional by checking contacts on the case of the pack. The most common type of battery used is the nickle-metal hydride type (NiMH) which has a nominal voltage of ~1.2 volts.  If the pack is rated 6 volts, you could measure either 4.8, 6 or 7.2 volts with the last one the most likely. If it measures 4.8 or 6 volts, it probably has one or two cells shorted, making it useless.
The charger could measure all over the map; many of them are unregulated and if they are rated at (for example) 9 volts, they could easily put out 14-20 volts when they do not have a load on them.
If those two items seem to check out OK, then the regulator in the system has gone bad. This might be on a separate board inside but to check it out, you really need some technical experience, otherwise you don't really know what you are seeing or looking for.
Sep 23, 2008 | Dell Inspiron 5150 Notebook
Toys Logo
126 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
