Question about Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts
How far off the floor do i install hot water baseboard heaters
I am installing some baseboard heaters in my house and need to know how far off the floor these should be installed.
    Problem Solver:
  • 7 Answers
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Posted on Jan 24, 2009
2 Suggested Answers
gary1121
  • 332 Answers
SOURCE: installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Posted on May 29, 2009
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
I am putting baseboard hot water heat in an older house that hase outlets in the way, is it alright to mount the baseboard above outlets . It would be about 12 inches.
Not sure that would pass code. But, you may want to check with the local building inspections dept in your area, before doing it. The other down side will be, the heat will start 12" of the floor rather than floor level. As you are aware, heat rises, so that would mean the lower 12" to the floor is going to remain cold. Want feel very good on bare feet that just jumped out of bed.
Feb 25, 2011 | Marley Electric Hydronic Baseboard Heater,...
New rad installation
Baseboard such as Slant-fin is made with a bracket that will allow you to run a 3/4" dia copper pipe back over the top of the finned area as a return pipe giving you a supply and a return on the same side. Both the finned pipe and the housing can be cut to any length and come in a 3' section from the factory.
Jan 20, 2010 | Marley Electric Hydronic Baseboard Heater,...
How do you reduce an electric bill in a all electric house?
The biggest wasters of electrical energy are Heat and A/c, water heaters,dryers and ranges. The more you insulate the less you have to cool or heat. If you live in a warm climate, consider installing an attic fan that runs on a thermostat or timer. During the summer allow it to run, during winter turn it off. Ceiling fans in rooms that are occupied create the illusion of being cooler, allowing the thermostat to be turned up.I'm not sure of the exact numbers but any thermostat setting on your a/c below 78 is more inefficient so try kicking the a/c up and the heat down. I'm a Florida boy so I can't tell you much about baseboard heaters. I know that anything that heats things up cost a lot in energy.
Consider installing a hot water heater timer. Commonly called a "Little Grey Box". Whenever your water heater is not actually being used it is still heating the water. A big waster. Once installed set the timer to cycle the water heater off during times when you commonly don't use it. Overnight,when your at work etc....
Somewhat antiquated, but a clothesline always uses 100% less energy than a clothes dryer. :) Short of this, try to fill the dryer all the way and make sure your dryer vent and lint trap are clear.
Microwaves draw 1/3 the energy of a range and run for 1/10 of the time. Microwave as many things as you can. In our house we have started microwaving canned veggies and boxed side dishes and such.
These are the big ones I've done at my house. A lot of the other things seemed to be more work than they are worth. Some actually end up costing you more if you don't own the house for decades.
There are many sites you can visit such as your local power company and possibly your local government pages.
Good luck. I'm in the same boat with the high power bill.
Mar 24, 2009 | Fahrenheat F2543 Baseboard Heater
Installing hot water baseboard heater
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Three of four zones, baseboard heat, warm house, why not fourth
Go to the last heater in the zone and look for a bleed off valve so you can get the air out of the system. you may have to bleed it off several times as the air works itself thru the system. usually there is a automatic air vent on the very highest point that the system has. Let me know if this helps and have a Merry Christmas
Dec 23, 2008 | Heating & Cooling
Tripping breaker
What were you wiring? Usually the white wire is a neutral which is connected to a white wire or your neutral bar in the panel.
sounds like you either "crossed-phases", connected a red and black wire together somewhere or you have a "ground fault", a hot wire is somehow contacting something connected to ground or neutral.
would you write me back and let me know what you were installing and what you did other than what you wrote here so far.
Dec 08, 2008 | Fahrenheat F2543 Baseboard Heater
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
Dec 01, 2008 | Marley Electric Hydronic Baseboard Heater,...
Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts Logo
2,160 people viewed this question
Top Marley Heating & Cooling Experts
Paul Carew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
