Question about Plumbing
Maax neo round shower stall continues to leak at bottom where it meets wall. Keep recaulking. Same results.
    New Friend:
  • 169 Answers
Many times there are small cracks on the material, it can be hard to see but opens up when someone is in the shower.
Posted on Jan 22, 2013
4 Suggested Answers
TBlessed 1
  • 61 Answers
SOURCE: leaking maax shower drain
try this:
you might but it will depend if it is pvc then yes any other material you might be able to use a waterproof epoxy but it will harder to repair because of the epoxy but the pvc you can prime and glue the seam from the inside..
Posted on Nov 12, 2008
  • 35 Answers
SOURCE: hi we just bought a maax breeze neo corner shower
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
Posted on Nov 19, 2009
  • 157 Answers
SOURCE: Trying to install a Maxx
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Posted on Mar 26, 2011
Is there any problem with using silicone on maax mediterrian III shower walls
I looked at the installation instructions for mediteranean III at this Maax site. It says silicone sealant is to be used. Unsure where you noticed mentioned of siliconized latex.
http://www.maax.com/en/products/showers/showers-kits/mediterranean-iii-tm
Sep 04, 2014 | Maax Breeze: One Piece Round Shower...
I have a Maax Neo-Round Corner shower that leaks under the track the doors slide on. I have caulked inside & out but still leaks. Any suggestions????
You may have to remove the doors and the track and reinstall the track on top of a "bed" of caulk or sealant to prevent migration of moisture underneath. The leakage also may be caused by moisture running down the inside of the doors during active showering. Check also for warpage in the track that would cause it to seal unevenly
Nov 10, 2012 | 2003 GMC Envoy
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
Maax neo round stall leaks where base meets wall
Many times there are small cracks in the panel or the base. It may not be able to be seen until someone is standing in the shower.
Nov 04, 2012 | Plumbing
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
Hi we just bought a maax breeze neo corner shower how do i install the two back walls do you use glue or what?
Nov 19, 2009 | Maax Breeze: Two Piece Round Shower Module...
Plumbing Logo
219 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
