Question about Whirlpool Duet GHW9150P Front Load Washer
I need to remove a Whirlpool Duet Sport front-load from the "pedestal" it is installed on. The spin cycle causes too much vibration. How do I loosen the bolts or height adjusting screws that fasten the washer to the pedestal?
  • 640 Answers
Wow you really should remove draw and lay hold unit down..thate how they put it on ..inside remove draw
Posted on Jan 05, 2009
During the spin cycles, the machine makes noise, almost like an airplane ready for take off. It also shakes and "walks". As the spinning increases, the noise and shaking increases. The shaking...
Not an expert but had identical symptoms. Problem was the loosening of the nut 27mm on the main pully. Simply remove lower back panel (16- torx 20 screws ) and tighten same.
If this does not hold over time, the pully hub has been damaged, and a shim, ( shopmade washer ) may solve problem. Remove belt, and pully, look for damage, and install thin shim, so that the nut will not bottem out on bolt before tightening on the pully hub. Good Luck, Lee
Mar 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer knocking noise when in spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Six year old Whilpool Duet washer on pedestal and level front and back still vibrates excessively and makes loud noise when spinning water out of machine. Is sitting on concrete floor. Have owned since new...
check the inner struts on the bottom of the tub you need to remove the front panel some have a split lower section so you can access inside where the struts are also check that the struts are not worn out hope this helps
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool Duet Sport Front Load - Spin Cycle Noise
Had one do this. Turn machine around look at bottom two corners. Machine comes with metal rods to stabilize drum during shipping. Installer forgot to pull those out on mine. Once I removed them noise quit.
Jul 07, 2008 | Whirlpool LHW0050PQ Front Load Washer
In less than 2 weeks we had to have our new Whirlpool Deut Sport ht replaced because it literally beat itself to death. The 2nd machine had a failed computer board and after replacing machine still beats...
All washing machines rattle and vibrate during a cleaning cycle, and especially more so during the rinse cycle.
If you have placed it not a pedestal, make sure that the pedestal does not have wheels, or thin legs, as it will invariably move. It is best to place the unit directly on the floor itself.
If you still find that the unit vibrates excessively, it could indicate a faulty bearing on the drum, and I'd recommend getting it replaced once again under warranty..
Jun 12, 2008 | Washing Machines
Whirlpool duet sport..vibrates during spin and "walks"..on pedistal.sitting on tile
I just bought this washer and had two problems with it. 1 the vibration at medium spins and 2. a squeeking spring (every time the drum rotates a little squeek, but when spinning the squeek sounds constant.
What I discover in solving both my problems with the same solution. I had to ensure all 4 feet well on the ground and that the top of the washer was perfectly level. At one time I was out only about 2 mm on one side, but the bubble was slightly to one side on the level but still in between the level's markers. I tested with a load, and both problems were still there. Turn feet 1/2 turn on the side needing adjusting. Ran another load and you guessed it, no squeak, no vibration, spinning was quiet, I had to go over to check to see if the machine was going through the cycles. I couldn't believe that a few millimeters could make such a difference.
Now I am pleased with the performance, not to mention how clean the clothes are and the savings on water and drying.
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
350 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
