Question about Sewing Machines
Can I use my new Mac Pro with my janome embroidery machine MC1100
  • Sewing Machines Master
  • 7,365 Answers
You might contact Janome customer service and see if the computer and embroidery are compatable
Posted on Nov 05, 2012
SOURCE: Kenmore 19005
The memory card cannot be over 128 mb. Also the files need to be .jef format and stored in an emb folder on the card. I hope this helps.
Posted on Sep 18, 2008
bargainbox
  • 1388 Answers
SOURCE: embroidery machine janome 300.
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 3 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Dec 28, 2008
  • 8 Answers
SOURCE: Janome Customizer 10000
There are different programs for 350E. I think, you was buy program different.
Posted on Jan 11, 2009
  • 152 Answers
SOURCE: husqvarna viking designer 2 embroidery machine. Wont work on my
Buy a PC, or get the program that mac has that supports pc programs. I've seen it work so I'm sure it's an optioin. Mac people don't like the program, but it will create an environment that supports PC programs.
Posted on Oct 24, 2009
  • 233 Answers
SOURCE: Lost power cord for Janome
Try https://www.sewshop.com/#/Cords___Controls-8-4020.html. They have Janome power cords. The one fits the Memory Craft. Most of the manufacturer's use the same power cord for most of their machines.
Posted on May 12, 2011
Will the premier embroidery System work on my janome 9900?
Hello Maria
The Premier Embroidery System software is compatible with all sewing machine brands.
Once an embroidery design whether created or downloaded can be saved in various embroidery formats. You can save the design as .jef and use it in your Janome embroidery sewing machine. If the same design is saved in other formats, it can be used in other sewing machine brands.
The Premier Embroidery Software is amazing.
Please let me know if this is helpful.
Happy stitching
Mar 03, 2017 | Janome Sewing Machines
Can I use Bernina Embroidery Cards with my Janome MC9500
Getting That Embroidery Design To Your Janome ...
https://tv-sewingcenter.com/janome/getting-that-embroidery-design-to-y...
Aug 21, 2010 - The designs will then be recognized by your embroidery machine, and you will spend more .... you can use either jef or jef+ for your 11000se .... like to know what brand,size and card reader to purchase for my Janome MC 9500. ...... Bernina · Elna · Embroidery · General · Janome · Necchi · Quilting · Sewing ...
Janome MC9500 100 Stitch Sewing 5.5x8" Embroidery ...
www.allbrands.com/products/8905
Janome MC9500 5.5x7.8" Embroidery .jef Format Replaces Memory Craft MC9000 ... to creative quilting and clothing construction, your sewing projects will go ... designcards) or Compact Flash Memory Cards (as used in digital cameras). ... My set screen controls for contrast, In./Cm. designation, and other customization
Which format does my machine use? - Embroidery.com
https://www.embroidery.com/help.ec?docID=225
Dec 26, 2015 | Janome Sewing Machines
Tengo problemas con maquina de bordar janome mb4, me distorciona el bordado. I have problems with mb4 janome embroidery machine, embroidery distorts.
If your embroidery is distorted be sure you are using the right stabilizer for the fabric you are doing the embroidery on and enough for the density of the design.
I hope that helps.
Dec 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Does Janome have software available for a MacBook Pro and Memory Craft 10000 Digitizer?
No:
I just got an email this morning from Wilcom that suggested that they are working on something for a Mac. "Wilcom Elements 3" If another expense for new software isn't an option I would consider getting a secondary computer.... a PC.
If you can run PC at all... go to a pawn shop and buy one specifically for your embroidery machine. A couple years ago I got a 1 year old PC for my husband for $60 at a local pawn shop. I needed to clean out the former owner's personal pictures and tax info... but I was able to access and restore the factory settings and it runs like new.
Feb 26, 2013 | Sewing Machines
Can you attach a computer (laptop) to a janome memory craft 4900qc
Any sew and vac store that services Janome would be able to order that for you.
Sep 25, 2012 | Janome Memory Craft 4900QC Mechanical...
Lost the instruction manual janome decor excell II 5024 Pls email at the following email address
at janome website they have a operation manual
under machines it will show different names like embroidery-sewing/quilting
look for the one that says retired
it will bring up a picture under the picture it will say machines in this catagory
it has a janome decor excell 5124
Nov 24, 2010 | Janome D'cor Excel Pro 5124 Mechanical...
How to I randfer embroidery designs on a flash
If the designs are already on a formatted* flash drive and in the format of the embroidery machine and the embroidery machine has an USB Port-A receptacle, you just plug it into the machine.
If the flash drive was not formatted for the Janome, then this may help - http://janome.com/fusetalk/forum/messageview.cfm?catid=7&threadid=639
Get a new flash drive and start fresh.
Create a folder on the PC's hard drive and name it Embroidery Downloads and copy or send from the flash drive you now have. Keep the flash drive as a backup.
After you format the new flash drive, you can then copy as needed from the Embroidery Downloads folder. Just do a couple.
Mar 26, 2010 | Janome Sewing Machines
I just purchased a Janome CM350E and need Customizer software
You can use any machine embroidery software brand.
There are many that have free trials and demos. Embird is one brand that is very popular.
You start with Embird Studio and then add other programs as you become more knowledgeable about machine embroidery.
All ME software products run on Windows XP, Vista and some are now compatible with W7.
You can find more machine embroidery discussions/questions and answers at sewforum.com
Mar 25, 2010 | Janome Memory Craft 10000
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
