Question about Whirlpool AKZ159IX Oven
Hi my Whirlpool AKZ431 oven suddenly started to show the F07 error message. What does this mean and what can I do to fix it? Thanks a lot for any help! :) NB: I did not find this oven in the
Model: Whirlpool AKZ431/nb/01 Came after warming pita bread.
  • 84 Answers
SOURCE: Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Posted on Nov 09, 2009
  • 401 Answers
SOURCE: Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Posted on Jan 12, 2010
localwonder
  • 6784 Answers
SOURCE: Whirlpool Model GBS307PB00 has error codes
HI. The reason for the PF code will be the result of the power cycling. When you switch the breaker to the off position, the main control board assumes that there has been a black out, thus, triggering the PF code. This is not your principal issue here. The F3-E0, which is your main issue, is the result of a failed oven temperature sensor. The control has sensed that the actual sensor circuit is stuck open(Not functioning or energized).
Your main control board is programed to shut off the entire unit, due to this apparent failure within the oven temp sensor. The necessary actions are to have the affected part replaced, asap. I would, also, advise to preform an electrical test. I will list the entire procedure below. Follow carefully, and with caution. Make sure that your units is unplugged before administrating the testing procedure.
Sensor testing procedure:
First,you will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Apr 05, 2010
Testimonial: "Thank you for your help. The problem appears to be intermittent. "
TheMobilian
  • 8220 Answers
SOURCE: F1E1 error on my whirlpool oven. What does this
F1-E1 Defective ERC Replace ERC
ERC= electronic oven control
Posted on Jun 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error Code E2 F3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%
Posted on Sep 29, 2010
Hi my whirpool oven is stating F 03 what do i have to do? Thanks
Usually the F-03 error code means you have a bad oven tempreture sensor. To test the tempreture sensor you would use a multimeter set to ohms. At room tempreture the sensor should read between 1000-1100 ohms any less then this and you would replace the oven tempreture sensor in the unit. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s I also looked afterwards in your service manual and the F-03 error code does refer to the oven tempreture sensor
Sep 13, 2011 | Whirlpool RBS275PD Electric Single Oven
Can not find model no.of the oven. Fault F07 on
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 09, 2011 | Whirlpool RBS307PVS Stainless Steel...
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My whirlpool oven has come up with code f 02 and wont work
Hello, the F02 error code on your oven means oven temperature sensor shorted and it can only be fixed by replacing the oven temperature sensor.
Thanks
Jul 14, 2010 | Whirlpool AKZ159IX Oven
Whirlpool double ovens error message e6 f2
good day,
hope this link below will solve your problem.
ovens
Mar 26, 2010 | Whirlpool RBD245PDS Electric Double Oven
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
May 18, 2009 | Dacor ECS130 Epicure Electric Single Oven
Whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
Apr 01, 2008 | Ovens
Whirlpool AKZ159IX Oven Logo
119 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
