Question about Dell 924 All-in-One InkJet Printer
My printer tells me that theright cartage incorrect and i have done everything i know to do. When that message goes away ittells me that cover is open can you help
  • Jeff May 11, 2010
    Is this a new printer? It sounds like one of the shipping pieces or tape that holds parts in during transit is still in the printer.
I had the same problem then I put in another new catridge and then it worked. Obviously the new previous cartridge was no good. I returned the bad cartridge. I hope this is your same problem so it can be solved.
Posted on Jan 07, 2009
My sister has a Dell 964 All in one. The printer seems to have loaded correctly into her computer but the printer keeps giving a Left and Right Cartridge Error. Even though the ink was never used she...
Are you making sure to remove the protective tape that covers the cartridges electrical contacts? Also make sure that the cartridges are the correct ones. I know its sounds like a dumb request but it can be very easy to have the incorrect cartridges installed. I have done it before myself! If you are positive that the cartridges are indeed the correct ones and the protective tape is removed, make sure the cartridges are in the correct holder, black goes in a specifice side/holder as does the color cartridge. Visually inspect where the cartridges sit in the holder and where the contacts meet in the carriage, make sure there are no obstructions. I hope this helps.
Jul 20, 2010 | Dell Photo 964 All-In-One InkJet Printer
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
Hi, my printer keeps giving me a cartridge error.
remove cartage and clean contacts with a soft cloth. also clean contact inside cartage holder and incert nice and firmly, hope this helps in some way
Dec 01, 2009 | HP PSC 2175 All-In-One InkJet Printer
The pages are coming out all black, the text i'm
i think it is cartage fault. drum of cartage do this many time. while we reffil dust of cartage we face same problem. once atime check changining another old cartage. u came to know problem.(nepal)
Oct 02, 2009 | Konica Minolta PagePro 1390MF All-In-One...
Smsung 4521 printer error toner empty
If we reffii samsung tonner some time these printer gave that type message. it means to re set the cartage. we should reffil cartage before reciving that message.while we get tonner low message. your cartage have may be green cheap or fuse. change it then your printer work properly. chaingining cheap or fuse can be use after reset.. so change it re old them.
Jun 16, 2009 | Samsung SCX-4521 All-In-One Printer
PSC 2200 All 4 lights keep flashing the message is to remove and check cartridge.
Hey I figured out how to fix this problem. The problem is not the cartridge it is the clamp that holds the cartridge down if you look at the bottoms of the cartridges the offending cartridge is lower. I beleave it is the spring that gets tired in the hold down lever. What I did was put a piece of cardboard behind(above) the black plastic with spring in the lever. What I used was a coaster from the bar and that tightend it up enough and it worked right away.
thanks
Cory
Jun 30, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer not accepting cartage X7170
it might be that your machine is a lexmark one.
i dont have any ideas about lexmark. just canon and espacially brother printers.
sorry!
Mar 19, 2008 | Office Equipment & Supplies
Color ink senser will not ingage
What was telling you it was the sensor, did the printer give you an error message. Is this a standalone unit or hooked to a pc?
Dec 29, 2007 | Canon PIXMA iP90 Mobile Printer
Installed new cartridges; keep getting error message
I'd say your using dodgy aftermarket or non HP cartridges, you could put your old ones in and see if message goes away, if having problem when using with Original HP cartridges post back and I'll did deeper for you.
I dont work for HP, I do know printers :-)
Dec 28, 2007 | HP Deskjet 5440 InkJet Photo Printer
Dislocation of cartage in hp deskjet d 2360
see dhanraj your problem just simple what u do is just remove the usb sable from the printer and switch on the printer and when the printer head move open the top cover and just quickly switch off the printer from main power supply . the head will be in the middle now gently remove the catridge. let me know are you able to fix this bye
Sep 28, 2007 | HP DeskJet 5150 InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
42 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
