Question about Electrical Supplies
I have DYNACORD powermate 1000-3. it's effect board is damaged. i want to buy new effect board. please help me to buy.
2 Suggested Answers
  • 5159 Answers
SOURCE: Dynacord Powermate 1000 Mixer MK1 manual, where
Do you mean teh Powermate 1000 powered mixing board? Dynacord has the manuals for some of their products on their site: http://www.dynacord.de/en/products/7/5/29_powermate.html . The direct link to the manual for the PowerMate 1000 is http://www.dynacord.com/downloads/PowerMate2_Manual_Vs02.pdf . Note the English documentation starts on page 31.
I hope this helps.
Posted on Oct 01, 2011
Have a marshall mg250dfx from usa so it is 110 v but i'm over seas and I use it with a step down transformer 220in-110out and it worked perfectly for some time but today wile i was playing it started...
Assuming the power in is good (I would check that first though, AC voltage going into the amp), then plug a patch cord(any 1/4" to 1/4") cord into the effects loop on the back of the amp and insert and remove a plug into the headphone jack a number of times to clean the contacts(headphone jacks and effects loop jacks are normally switching jacks that pass audio when not in use). Still not working?... If the pots(gain, volume and tone controls, etc.) are scratchy that could be the issue. The input jack could be the cause(damaged, cracked solder or circuit board trace). Wiggle the input jack to see if that causes or corrects the problem. A little WD-40 works wonders on correcting dirty jack issues. If none of the above are the cause then it is likely a cracked solder joint, trace or component lead which would have to be resoldered/repaired (maybe dirty contacts between the small effects board and the main board). Also watch the overdrive channel LED when the audio drops. If the LED goes off could be a power supply issue or a channel switching issue. Tapping on the amp will help indicate bad connections, cracked component leads or damaged traces.
Jul 03, 2013 | Music
Dynacord Powermate 1000 Mixer MK1 manual, where can i get one?
I hope this helps.
Oct 01, 2011 | Electrical Supplies
My new (used) Sony Trintiron recently took a fall and the screen was damaged. The damage appears to be a gash approximately 4-41/2 inches long and 1/4 inch wide. Is there a way I can fix this or get a...
The tv CRT-(tv tube) screen itself is broken now or dying already and tv PCB board broken require replacing too,tv will still work after replacing PCB board or repairing it but tv will not be watchable becauuce tv screen will all mess up like screw up picture colors will have black and blue colors be all over the tv screen.Tv now will not be worth repairing if require replacing CRT-(tv tube) will cost the same as a new tv if tries replacing CRT-(tv tube) if u still can buy it.Can't buy analog CRT-(tv tube) anymore.Sorry time to buy a new tv.
Apr 14, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Were do i get a la-3181p v5000
Ebay. Any V5000 full-featured AMD motherboard will work. There are several with very minor internal updates that really have no functional effect. Reconditioned is as good as new. Look at the connectors on the seller's photo to be sure you are getting the correct PC board. There are many confused eBay listings.
If you buy a used or reconditioned board, check the USB connectors before installing it. USB abuse and damage is a frequent problem.
Buying Hint: You may find that a damaged V5000 with a good motherboard is a better buy.
Good luck.
Sep 15, 2010 | HP Compaq Presario V5000 V5100 V5200 V5300...
Drawing of Cobra 2 Sub box
Alright, I looked up that sub and I think I know what you need. First and most importantly every sub woofer enclosure is different-made for the sub woofer you will be using. Unless you have the same exact model DYNACORD is using, your box will be slightly different. In fact depending on the sub, your box may be dramatically different. There are some people, like myself, that could help design an enclosure for you but they will probably charge for their services. Either way you can go on the internet and look at some designs to give you an idea of what you need to build. The particular design DYNACORD chose to use is called a "Vented direct radiating cabinet" (it also uses a couple other electronic goodies) a little complex to understand and build. Sure you could try to copy it but it won't work right unless you have the same sub. In fact I use a computer program to assist me in this regard, so don't feel bad if you don't get it right the first time. Good luck and I'll leave you with something from Dynacord.
-Dynami
DYNACORD´s COBRA-SUB is a vented direct radiating
cabinet, equipped with the high-power Electro-Voice EVX
180B 18" transducer.
Frequency response is 38Hz - 170Hz (-10dB), so the crossover
frequency to Mid-Hi cabinets, e.g. DYNACORD´s
COBRA-TOP can be chosen strictly application-oriented
between 80Hz and 160Hz.
The cabinet is equipped with an electronic circuit called
VOICE COIL TRACKING PROTECTION. This circuit senses
the terminal voltage of the transducer and simulates the
thermal behaviour of the woofer´s voice coil. In case of
potential thermal overload the power applied to the speaker
is reduced to a safe level.
Power amps up to 1200W/8Ohms can be used in order to
have maximum dynamic range without the danger of thermal
overload in non-controlled situations. The VOICE COIL
TRACKING PROTECTION exhibits “soft” switching characteristics,
so no annoying clicks or pops are audible. The
circuitry automatically resets after the voice coil temperature
has reached a safe value.
The COBRA-SUB cabinet is made of 18mm birch plywood.
All corner joints and braces are grooved and glued. The
cabinet´s surface is coated with an extremely durable Polyurethane
which exceeds the quality of a standard lacquer
finish by an order of magnitude. A powder coated steel grille
and a lockable cover protects the COBRA-SUB against
damage during transport and bad environmental conditions.
The connector panel uses two 4-pole Speakon connectors
(IN/OUT) for a safe connection and easy daisy-chaining to
other cabinets. The pin assignment is 1+/1-. Pins 2+ and 2-
are also connected between the two Speakon connectors.
When using DYNACORD power amp racks, the whole system
can be wired with 4-pole Speakon cables without any
danger of accidental wiring mistakes. Four recessed rigging
tracks and two webbing-strap points can be used for easy
“flying” of the COBRA-SUBs. The cabinet is equipped with
four large ABS feet that allow easy stacking and a “snap-on
flying” even in angled positions.
Two handles and four heavy-duty castors on the rear side
guarantee easy and safe transport.
Mar 15, 2009 | ElectroVoice EVX-180B Car Subwoofer
Behringer inboard effects modul board
BEFORE you throw away the board, I found a similar board in a different unit that had a SIMPLE problem. Check if your board has its own built in 5 volt power rectifier and regulator. The bad one I had required ONLY changing the DC filter electrolytic cap that, for my estimation, is undersized capacity wise.
Feb 23, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Electrical Supplies Logo
128 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
