Question about Husqvarna Garden
How to replace fuel lines on a husqvarna blower 225b xseries
2 Suggested Answers
  • 110 Answers
SOURCE: My husqvarna 225B leaf blower starts easy when
A few possibilities, first check the tiny little vent hole in the gas cap for a clog.Second, check the fuel filter in the tank. Third, remove the muffler and inspect the piston for scores and that the rings are free, remove ant carbon build up from the exhaust port. If the trouble persists its time to go into the carb, The pump and metering diapgragms will harden over time and loose their elasticity and cause this problem also
Posted on Nov 01, 2009
Husqvarna 350bt blower runs great but goes dead at half tank of gas.
I had a Husqvarna saw with a similar issue. Turned out to be a deteriorated fuel line. There was a hole in the line, sucking in fumes then cutting out the engine.
Dec 05, 2014 | Husqvarna 350BT 50cc Backpack Blower 50cc,...
Husqvarna 125b won't prime and run unless upside down. If turned right side up it dies. If I prime it when it's right side up it blows bubbles in the tank.
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
Sep 13, 2014 | Husqvarna 125B 28CC Gas Leaf Blower...
Repair broken fuel line husqvarna 125b
to replace the fuel line get a piece longer than the old one cut the last 1/2'' down to 1/3 place a stiff wire threw the hole and out the gas cap opening push the line over the hose and slowly pull back till the line pops out then pull the wire out and pull the line threw put the filter back on before pulling the hose all the way threw
Aug 11, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 225b leaf blower air purge diaphram replacement
The purge bulb is just a bayonet fit in the tank, press the two black prongs on the back of the bulb together and it will just pop out, note which pipe is connected to which connection on the purge unit so as to re fit correctly on the new purge.
Jun 23, 2012 | Garden
My husqvarna 225B leaf blower starts easy when cold and runs fine for about 5 min. then quits. Very hard to start after that.
Oct 29, 2009 | Husqvarna Garden
How do you install primer bulb on husqvarna 125b blower, which line to hook up where
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
May 02, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Garden Logo
82 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
