Question about Panasonic KX-T7731 Corded Phone
Programming change time
The individual phone only shows the time that is stored in your phone system. Time change should have been programmed to your PBX. If you have caller ID, call one of the phone numbers in the system and see if caller ID updates the time on the system. On the individual extension, hit the info button several times to get a "refresh" of the time/date.
Posted on Nov 05, 2012
I have a ET100C and the lights will only stay on for a few seconds in both manual and auto modes
Before you attempt any reprogramming, you might be better served by performing a RESET on the clock. TO RESET TIME SWITCH COMPLETELY: Press the recessed RESET switch for five seconds to remove all eight available events and to reset time of day clock to 12:00 A.M.
After resetting, try reprogramming again. The procedure below is copied from the manual (which can be downloaded here):
TO MANUALLY TURN ON OR OFF: Program Selector switch must be in RUN position. In AUTO or MANUAL Press ON/OFF button. Display indicates load is either on or off.
TO SET TIME: Slide Program Selector switch to TIME SET. Press HOUR and
MINUTE buttons individually to select current time of day. Note that clock is a 12 hour AM/PM repeating clock.
TO SET OR CHANGE PROGRAMMED SET POINTS: Select PROGRAM mode with Program Selector. Note that the event display shows Event #1. There are eight possible programmed events. Four ON and four OFF which are programmed alternately. All available events need not be used.
Press the HOUR and MINUTE buttons separately to program the first ON time
desired. Note the ON indicator (OFF in the next step) will only be displayed after the hour has been selected unless an ON time was previously entered.
Press EVENT button. The display now shows the next Event #2. Press HOUR and MINUTE buttons separately to select first OFF time or Event #2.
Press EVENT button to select Event #3. This is the second ON time. Program the ON time by pressing the HOUR and MINUTE buttons. Repeat this procedure for up to 4 ON and 4 OFF times (8 Events) as required. Return Program Selector switch to RUN Position. Be sure Manual/Auto switch is in the AUTO position.
TO OVERRIDE PROGRAM: Program can be overridden at any time by selecting the MANUAL position. Program set times will be maintained but will not operate the controlled load(s) automatically.
TO CHANGE OR DELETE PROGRAM SET POINTS: Place Program Selector switch into PROGRAM mode. Press EVENT button to step through the eight possible events. Note that the times which have been programmed will be displayed or 0:00 will be displayed if no set point has been entered. To change an event time, press the HOUR and/or MINUTE buttons to change the time currently in the program to the new time desired. Press EVENT button to proceed to next programmed event. To remove a programmed Event: Press the ON/OFF button two times. When this is done, the display will show 0:00 and the event number.
I hope this helps & good luck!
Nov 16, 2011 | Intermatic ET100C Energy Controls -...
Tip
Avaya Partner Phone System Programming
Programming Without Button Overlays: <br />Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.<br /><br />Avaya Partner System Date Program #101<br /> <br />Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.<br /><br />Considerations: <br />The System Date date-stamps the back up files when you use Backup Programming.<br /><br />Programming Without Button Overlays:<br />The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.<br /><br />Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Day Program #102<br />Use this program to set the day of the week that appears on system display telephones.<br />Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:<br />1=Sunday<br />2=Monday<br />3=Tuesday<br />4=Wednesday<br />5=Thursday<br />6=Friday<br />Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.<br /><br />Avaya Partner System Time Program #103<br /> <br />Considerations: <br />Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.<br /><br />Programming: <br />To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
on May 27, 2011 | Lands Phones
Can not open programs since daylight saving tme has change. All programs were converted to something else. I cant get into to change daylight saving help!
Time change has no effect on programs working.
Try changing time in control panel Time&Date link?
Manually run the internet time updater?
What do programs look like they were converted into?
Different language? Check Language settings?
Hard Drive got corrupted? just a coincedence?
Apr 04, 2010 | ZT Group CISNET A7022 PC Desktop
How do I change the time on a KX-T7730 phone?
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
Mar 29, 2010 | Panasonic KX-T7730 Corded Phone
How do you change the time on the phones. Since Daylight Savings time My clock is off by an hour
How do I change the Time and Date on a Merlin Legend system?
To change either the Date or the Time on the Legend system, you must program it from the main System Programming console (MLX-20L). This will change the Time or Date on all the display phones throughout the system, except the ATL (Analog) display sets. These phones must be programmed on each individual set.
How to change the Date in the Legend system:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit.
  4. Press System.
  5. Press Date.
  6. Enter date in following format: mmddyy (where MM is the month, DD is the day, and YY is the year).
  7. Press Enter.
  8. Press Exit.
  9. Press Home to exit programming mode.
How to change the Time in the Legend system:
  1. Press Menu.
  3. Press Exit
  4. Press System.
  5. Press Time.
  6. Enter the time in military/24 hour format: HH:MM (where HH is the hour, 01-24, and MM is minutes, 00-60).
  7. Press Enter.
  8. Press Exit
Nov 04, 2009 | Lucent Merlin Legend MLX-20L Phone
Cant Change the display name
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
Enter the year.
button.
day.
Set the time.
are done.
Jun 27, 2009 | Panasonic KX-T7730 Corded Phone
How do I change the date and time?
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
are done.
Feb 24, 2009 | Panasonic KX-T7730 Corded Phone
How do I change the time?
The Macrotel Excel, Macrotel MT-16 and the Prostar 816 are all very similar in programming. The following information should work on all 3 KSU's of any revision or software level.
To Enter programming: Must be done before any programming
Depress # (Programming)
Dial 20 (MMC Disabled)
Enter Password [Default is 1234] {or it may be 4321}
Dial 1 to enter programming mode. Programming mode will turn off automatically after a few minutes of non-use.
Dial # again
Then
To change Time and Date:
Depress
# (Programming)
Dial 55 (YY MM DD W HH MM)
Input new data:
YY= year
MM= month
DD= day
W= weekday [0=Sun 1=Mon 2=Tue 3=Wed 4=Thu 5=Fri 6=Sat]
HH= hour (24 hour mode)
MM= minute
All data must be entered each time or changes will not be saved.
Dec 04, 2007 | Samsung Prostar 824 Keyset Telephone
Change the time on phone system
1) press "Program", then * *, then 1234,
2) press "0 0 0",
3) press "speaker" two times,
4) change the time
5) press "store".
6) pick up the receiver to complete the change.
Do this change on the "lead" phone and it will reset all the others on your system. Not exactly an intuitive process to be sure!
Nov 27, 2007 | Panasonic KX-T7731 Corded Phone
Change Time and Names
On your Intertel Encore system you can program from a phone at extension 20. Intertel does not allow the sale of the manual to end-users (you) only Intertel dealers have access. I can help with the time change: From EXT 20 press the PROGRAM key, use the arrow keys to scroll until "System Programming" is displayed. It will ask for the password. The default is 1111, if it's been changed you may be in trouble... You would then select "System" then Select "Time and Date" - change the time (24 hour format) and date (MMDDYY) then hit the SPEAKER button to complete programming. I hope this helps. I have not done this myself, just passing on the instructions.
Jan 30, 2007 | Inter-Tel Encore 618.4001 Phone
Panasonic KX-T7731 Corded Phone Logo
148 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
