Question about Treadmill Doctor Proform 590Qs Treadmill Front Roller
Motor runs on and off
On slow speed dont move , at high speed move , but now not moving at all
  • 81 Answers
Must insert in it oil.
Posted on Jan 16, 2013
My pfaff 1222e is running slow
1. Remove any stuck material from the feed dog, bobbin area including the hook (pointed object under bobbin). Lubricate as you go.
2. Remove top and end of sewing machine to look at the motor and belt. Place pressure on the foot pedal. Still slow?
3. With bolt attached to motor release the pressure on the belt. Now, place pressure on the foot pedal. Did you notice any increase in speed?
4. Apply pressure on the foot pedal and simultaneously adjust the motor. Adjusting means tightening of the belt and making it move in a straight line. (If it doesn't move straight it puts pressure on the motor so it will move slow.) When you have adjusted the motor to the right position the motor will be at it's highest speed.
5. If the pressure foot is the problem it will require a pro to take care of it.
Apr 16, 2015 | PfaFF Sewing Machines
Client run on treadmill then suddenly its stop and display an error speed, then 5 seconds treadmill belt moves again and moves faster whats the problem of that?
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Feb 25, 2011 | Life Fitness 9100 Next Generation...
Vw golf mk3 wipers not working,fuse ok. sometimes work if blades assisted manually
WIPER ARM LINKAGE COULD BE BINDING.REMOVE WIPER ARM TO SEE IF WIPER MOTOR OPERATE SLOWLY.IF YES CHECK TO MAKE SURE WIPER MOTOR GETTING GOOD GROUND CONNECTIONS BY CHECKING MOVING WIRES .IF WIPER MOTOR SPEEDS UP YOU HAVE GROUND WIRE PROBLEM. IF WIPER MOTOR REMAIN SLOW GROUND WIRES CHECK OUT OKAY.REPLACE WIPER MOTOR.IF WIPER MOTOR RUN FAST NORMAL SPEED AFTER DISCONNECTING WIPER ARM.WIPER ARM LINKAGES IS BINDING OR NEED SOME LUBRICATION TRY WD40 SEE WHAT HAPPENS.LUBRICATION DONT HELP WIPER LINKAGE COULD BE DAMAGED.
Nov 18, 2010 | 2000 Volkswagen Golf
Blower works only in high on my mitsubishi lancer 2000, what is the cause
The "blower motor resister" that slow the motor down to the slower speeds is broken or burnt out. The motor is running at it's default setting of full speed. The resister is usually located on the blower motor housing so it gets lots of air moving over it (it gets hot). It is held on by two or three screws and when you take it out you will see several different sized coils (one for each speed). Hard to get to easy to replace.
Oct 02, 2010 | 2004 Mitsubishi Lancer
Heat/ac fan only blows on high
Check the heater control switch,,,,,and the number of wires at the heater motor....Some motors have more than one winding...in which case there will be three or more wires going into motor..there can be burnout in those windings and will require a new motor....check the plug which attaches to the motor....can be bad connection...or at the switch.....but if there is only two wires....then the heater switch uses resistors to slow down the different speeds...and direct connection for high speed....and the problem is definitely the switch...
Apr 27, 2010 | 1996 Lincoln Town Car
1985 gmc k1500 wipers only move at 1 slow spped, interminttent doesnt work at all. How fast is fast and why is fast not working?
Slow is the same speed as 'mist'. Mist is when you twist the control arm backwards to induce a single swipe. If you hold it, you will run the wipers in low speed. Fast is faster than that. Probably by 30% or more.
Turn the wipers on high speed. Wiggle the connector at the wiper motor. If the wipers run sporadically as you wiggle the connector, you either have a bad connector or a bad circuit board on the wiper motor.
Jan 15, 2010 | 1985 GMC K1500
I just installed a Hunter five minute fan which says it is called the augusta. I have also installed several other hunter fans in my house through the years, and they seem to move extremely fast especially...
Speed is not a factor in moving air. You can move air with a little fan that runs real fast or you can move the same amount of air with a big fan that moves slow.
It is the pitch of the blades that moves air. Big blades with steep pitch moving slow are comparable to little blades with shallow pitch that move fast.
It seems to me someone is trying to baffel you with bull**** when they tell you CFM = watts or something similar.
The real question is, is the fan moving the air necessary to achieve the result you desire? If yes, speed is not really a factor.
Let me know if this helps you.
a
Sep 22, 2009 | Dryers
I have an a/c unit that is blowing on high speed.There are 3 wires:black, red,blue,white(and 2 brown for the capacitator)To reduce the speed from high to medium do I just disconect the high speed...
The reason the a/c is on the high speed is to move the air because cold air is harder to move, slowing down the speed may cause your a/c to freeze-up. You can try changing the speed by reading the wiring schematic, take your time to become confortable with the schematic, and it will tell you which wire color conforms to each speed, locate the high speed wire color, and you will find that connected, locate the medium speed wire color, then disconnect the high speed and reconnect the medium speed wire in it's place. Be sure to tape the end of high speed wire so that it is insulated from the cabinet. ABOVE ALL MAKE SURE THE POWER SWITCH IS OFF BEFORE ATTEMPTING THIS
Jun 23, 2009 | Heating & Cooling
Treadmill Doctor Proform 590Qs Treadmill Front Roller Logo
46 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
fordexpert
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
