I need a manual for a Craig Model # 41025 projection clock radio
Having trouble setting the time on the projection lens
SOURCE: complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Posted on Mar 09, 2008
SOURCE: How to set time/alarm GE Auto Clock Set Radio Model 7-4892A
I have a solution for the GE Auto set clock and radio model number 7-4892A. The only way that I had found out just by accident is that you are suppose to hold down the manual clock set until you start to see the Year and then the Date. There you will be able to set it to the correct date or year.
Idea from
Guest
Posted on Mar 11, 2008
sg1972
  • 225 Answers
SOURCE: Set the clock to DST
Try this link and follow the instructions.
http://www.lacrossetechnology.com/3143a/manual.pdf
Posted on Mar 26, 2008
SOURCE: trouble setting time on innova clock radio w/ ipod dock
How do you set the alarm and it actually work?
Posted on Jan 04, 2010
SOURCE: instruction manual for a Tevion clock radio
how to set the alarm on Tevion fm/am digital alarm clock
Posted on Aug 16, 2010
Craig CM427 Clock radio CD player. How do get to standby mode to set the time?
Try Googling (craig)(CM427)(manual) without parens to get instructions.
Nov 08, 2017 | Craig Audio Players & Recorders
Craig electronics alarm clock Model#CR45367 how do i set the alarm?
Click on the button that says manual and it will download a pdf manual with instructions.
Craig Electronics Inc
Jan 28, 2015 | Craig Audio Players & Recorders
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
Sentry CR-106: setting the projector's time.
I found my manual!
To set month, press the "set" button 2 times then press "mode" to sequence month
To set date, press the "set" button 3 times then press "mode" to sequence date
To set hour, press the "set" 4 button times then press "mode" to sequence hour. (24 hour clock toggles with 12 hour clock)
To set minutes, press the "set" button 5 times then press "mode" to sequence minutes.
I hope this helps!
Oct 07, 2008 | Audio Players & Recorders
229 people viewed this question
 Grubhead
Grubhead
