Question about byD sign d:1070 DVD Player
Dead remote for ByD:SIGN under counter 7" lcd combo
What replacement remote is compatible to this unit? I've tried to train a couple remotes, but I fear either proprietary signal, or remote assembly in side tv is dead.
What thoughts do you have besides junking it for channel 3 usage only, using cable box?
Thanks a bunch, and Happy New Year from Minneapolis!
Steven
  • 55 Answers
Trying to match up a triantianyong TV-139F universal tv remote to this LCD TV DVD combo.
Search Results
    Universal Remote Controls - Encompass Parts
    https://www.encompassparts.com/staticlist/Universal_Remote_Controls
    TVs made since 1988. Works Mitsibushi . TVs only. Will not operate. TV/VCR or DVD Combo units. ... fully operate yout TV. Full function replacement remote for ToshibaTVs made since 1988. ... 2004-2005 LCD TV's. ON/OFF, CHANNEL +/-, ...
    Universal TV Remote ' eBay
    www.ebay.com/bhp/universal-tv-remote
    eBayUniversal Remote Controller 6 IN 1 TV DVD VCR Satellite Receiver Cable Box Audio... control for Samsung LED/LCD TV is the lastest product, easy to operate and ...damaged or needs to be substituted, or when you dxxire to have a combi.
    Codes For Universal Remotes ' Universal Remote Control ...
    codesforuniversalremotes.com/
Feb 05, 2016 | Universal Televison & Video
My remote is not working the tv. I have changed the batteries,
Hello,The first thing to do is to check to see if the problem is with the remote or the TV. You can check to see if the remote is sending a signal. The easiest way to do this is to take a digital camera or a cell phone with a built in camera. Point the camera at the top of the remote and press then press any key on the remote control. If the remote is sending a signal you'll see through the phone or camera screen a light illuminate on the top of the remote. If you see this light then the problem is with the TV. If you don't see this light you will most likely need to replace the remote with a universal remote or provide a model number to see if an original is available.
Jun 08, 2011 | byD sign d:2232 22 in. HD-Ready LCD...
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
I'm trying to program my ''Comcast'' cable box remote control to operate my byd:sign model d:5032M plasma TV. Comcast does not have a standard 4 digit TV code to use. How can I get the code as there is no...
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
Sep 19, 2009 | byD sign d:5032 50 in. HD-Ready Plasma...
I do not have a remote for my dell tv and the button are locked
what you can do is get a remote for the same kind of tv.. it doesnt have to be yours but try somebody elses remote for the same type of tv.. i know this works for the three or four samsung tv's i have in hy house
May 30, 2009 | Mitsubishi WD-52526 LCD TV
Remote does not work
try replacing the battery.
What I have done is open up the case and make sure all the water is dry. If not, use a hair dryer to dry it clean, being careful not to 'overheat' the unit in case you burn up any chips on the board.
If this does not work, replace it.
Feb 16, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Need to get parts for byD:sign lcd m#D:4242m
I bought 40 byd:sign 23" LCD screens from them about 1 year ago and installed them in a hospital enviorment. The sets are starting to fail. Do you have an address or phone number for them? I would be greatful for any help.
Respectfully
John Liljeblad
Amerisat, Inc.
858-505-1122
Jun 21, 2008 | byD sign d:4222 42 in. EDTV-Ready Plasma...
Byd:sign under the counter TV/DVD player
Did you try using the volume button *on* the TV rather than your remote control? If so, did it work? If it did work, then the problem is with your remote control and you should get a new one.
Jan 06, 2008 | Televison & Video
19tvr60
first try another remote.and play back try a vcr tape head cleaner. by 3m in a red case. those work.
Jan 10, 2007 | GE 13TVR60 Combo
Universal remote codes
NOT A SOLUTION, however my remote stopped working a couple months ago. I subsequently tried several universal remotes - none of these worked. An educated guess might be that the problem is NOT with the remote control unit, but rather something inside the set itself. This might also explain why the MW24FM1 you bought "didn't come with a remote".
Oct 23, 2006 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
byD sign d:1070 DVD Player Logo
98 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
