Question about Nintendo DS Lite - Onyx
My psp wont connect on my pc.. please help - Nintendo DS Lite - Onyx
  • Nathan B
    Nathan B May 11, 2010
    First, you've posted your playstation portable problem in the nintendo DS Section, So you might not get a faster answer.
    Do you have the USB Cord for your PSP?
    Did you install your motherboard USB 2.0 Drivers, the drivers come on the motherboard CD.
  • 124 Answers
Scroll over on psp menu to the usb connection click on it and have psp connected to computer then it should link and install and will work from there if you have already done this go to my comp and look for a letter such as f and clickon it this should be psp memorycard
Posted on Jan 05, 2009
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
My psp wont connect to my PC? i tried almost everything please help!
Hi dominic_prig,
Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. --> Alsomake sure the Memory Stick PRO Duo has been formatted for PSP. 2. Connect the PSP to your PC with a USBcable. 3.Press the "home" button on the PSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 09, 2011 | Sony PlayStation Portable (PSP) Console
My psp says update failed. Contact technical support for assistance.It wont turn off or work .please help
How did you try to update it? You should be able you connect it to your pc an force a fresh update to overwrite the failed one.
Nov 27, 2010 | Sony PlayStation Portable (PSP) Console
Psp cannot connect wireless network
  • Make sure you turn on your wireless switch on your PSP.
  • Go to Settings\Network Settings.
  • Select Infrastructure Mode
  • Select New Connection
  • Select Scan
  • Choose the name of your wireless connection and enter the Security key if you have one.
May 29, 2010 | Sony PSP-3000 Black Console
PSP Not Connecting to PC via USB
Hi rupasam,
Based on your concern, I suggest trying the following steps:
1. Before you plug it in make sure the PSP is in USB connect mode.
--> Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's not this is how you do it:
On the main menu, scroll all the way left to the "Settings" menu. Then select "System Settings." Then scroll to "Format Memory Stick" and press X.
2. Connect the PSP to your PC with a USB cable.
3. Press the "home" button on the PSP
--> at the lower left of the screen you can see the home button.
4. Use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
5. Press the "X" button, your PSP should display "USB Connection".
6. Please wait until your computer tells you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
7. Click on the drive letter that corresponds to the PSP unit.
Hope it helps,
May 29, 2010 | Sony PSP (Piano Black)
Psp Folders Wont come Out In The PC
you just go to system settings in ur psp then click on format memory stick and follow the steps.after u r done connect the psp and you will see the folders.format it from hte psp not the computer.thanks
Apr 23, 2009 | Sony PlayStation Portable (PSP) Console
My psp wont let me on the internet
Well first off have you a wireless router int he location you are trying to connect from? IF so make sure you configure the connection under settings
Apr 01, 2009 | Sony PlayStation Portable (PSP) Console
PSP
You need to have a wireless router connected to an adsl/adsl+2/dsl/cable modem it wont work with dialup once you have the wireless router connected to the modem you can select automatic settings under internet connection or something similar to that name
Dec 08, 2007 | Sony PlayStation Portable (PSP) Console
Can't convert psp files
you need an mp3 conversion programme like Nero, or media player 10 can convert your cd's to mp3 in the rip tab. but what it doesn't tell you in the instuctions is that you should make a new folder called music in the psp folders window when it pops up showing whats saved on your psp. Make sure you have a decent size duo memory card fitted as this is where the songs will be saved; not on the psp itself. But in your psp settings make sure you have selected USB connection or it wont connect and show anything on your pc. select your mp3 file on your pc, copy it and then go to the music folder you made open it up and then select paste, it will then go into the folder and then should show up in the music menu in the psp after you have disconnected the usb lead. the same applies to video or any other file you wish to put on the psp.
Sep 07, 2007 | Sony PlayStation Portable (PSP) Console
Nintendo DS Lite - Onyx Logo
27 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
