Question about Samsung Ovens
Samsung C61R2AEE child lock wont unlock - Samsung Ovens
I locked the child lock and it wont unlock anymore... It's Thanksgiving and the turkey is inside.
Quick try is to remove the power and see if it re-sets. Do not unplug try it from the fuse box. be careful.
Nov 26, 2015 | Stoves Ovens
Why is it showing a key symbol, an error code f10 and the door is locked?
usually a key symbol means that the appliance is safety locked. usually by holding down a button for 3-5 seconds to lock and holding down the same button to unlock. a child lock safety feature.
Jul 20, 2015 | Gaggenau EB 270/271 Electric Single Oven
CHILDLOCK WONT SWITCH OFF ON BOSCH OVEN
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Aug 05, 2014 | Bosch Ovens
How do I remove the child lock message on my Panasonic Inverter Microwave?
Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
Aug 20, 2011 | Ovens
How to unlock child lock form cylinda 265
Turn on the stove.. then press the + & - buttons at the same time and then again hold the - (minus button) until the LOCK L turns off.
May 09, 2011 | Ovens
We have a scholtes oven, we are in france, we don't know the model, child lock is on and we can't unlock it/open door
we had the same problem just now and we solved it.
Our model is a "Fi 466 S" that has three knobs.
Just push all of them at once, which makes the "loughing lock"-display go away. And then press just the middle one for a time. That unlocks the oven.
Hope to be of help.
Oct 14, 2010 | Ovens
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Mar 21, 2010 | Neff B1421 Electric Single Oven
I cant't get the lock to turn off
Try cutting the power to the oven for about 20 minutes and see if it will reset and release the door lock. Hope this helps.
Nov 18, 2009 | GE Ovens
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 | GE Ovens
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Ovens Logo
Top Samsung Ovens Experts
Pcm2048
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a Samsung Oven Expert? Answer questions, earn points and help others
