Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Won't shift into gear
Poulan pro 300 ex starts fine but will not go into forward or reverse
  • lburkhard611
    lburkhard611 Nov 04, 2012
    When I use the transmission release in the back to put into neutral to push it. It will not move
  • 4 Answers
SOURCE: Hard to shifet my poulan pro and wont go into reverse
Try loosening the belt tension to the transmission a little bit. Some of these are just stiff and you have to slip the clutch a little to rock them into gear.
Posted on May 25, 2009
SOURCE: poulan riding lawn mower starts but won't shift into any gears
where do you tighten the cable for the cluch
Posted on May 20, 2010
SOURCE: My Poulan 42-Inch 17.5 hp Briggs and Stratton
OK, so I had the same problem. Would not go into gear forward or in reverse. I took it apart and nothing seemed out of place or broken. I scratched my head for an hour... asked my wife if she had done anything to the machine while I was gone and she replied I only had a tire fixed!!! Bing bulb went off.... She had removed the tire from the shaft and had lost the SQUARE KEY for the drive shaft, one 20 cent square key for the drive shaft and it worked!! TA DAHHH!!
Simple fixes for simple problems.
Posted on Jul 20, 2010
SOURCE: poulan pro riding mower
check the square key on your drive shaft
SOURCE: I have Poulan model 27149 riding mower. Shifting
Mower stops after running 30 minutes COULD IT BE THE SOLENOID VALVE ON CARB FOR GAS LINE
need tune up kit #5122A
Posted on Aug 07, 2011
Atv wont shift into high gear
Is this an electric shift?? SORRY.. take it to a qualified professional!!
Sep 02, 2017 | ATVs
My 99 Buick LeSabre has been working fine - drove it and parked it but when I went to drive it again it starts just fine but will not go in to reverse /forward or any gear. Had no problems previous t
NO REVERSE ON TRANSMISSION
It
can be issue with gears or problem with transmission and needs to be rebuilt.
Also get the tranny fluid checked. If it\'s low, then such problems
occurs.
To
troubleshoot these types of issues, check the actual solved problems with these
types of issues.
There
are solved help links provided below: -------
Click
the link below and go through the details and diagrams to troubleshoot the problem:
2003 Lexus RX300:
Transmission Fluid Burnt Brown and not Shift to reverse?
http://whatisbyme.blogspot.in/2012/05/2003-lexus-rx300-transmission-fluid.html
2007 Chrysler 300: Transmission Stuck in Park?
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
2000 Toyota Camry:
Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
1996 Toyota Corolla: Transmission
Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
CV AXLE stuck in Transmission?
http://technoanswers.blogspot.in/2012/04/cv-axle-stuck-in-transmission.html
Transmission in reverse,
acts like it\'s in neutral?
http://schematicsdiagram.blogspot.in/2012/04/transmission-in-reverse-acts-like-its.html
Delayed shift and harsh
Shifting?
http://schematicsdiagram.blogspot.in/2012/04/delayed-shift-and-harsh-shifting.html
Dodge neon wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Dodge Automatic transmission will not go into
reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Dodge manual transmission will not go in
reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
1998 Dodge Ram: Not Shift
To Reverse?
http://schematicsdiagram.blogspot.in/2012/06/1998-dodge-ram-not-shift-to-reverse.html
Transmission leak on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/transmission-leak-on-toyota.html
Automatic transmission,
with no reverse?
http://howtobyme.blogspot.in/2012/02/automatic-transmission-with-no-reverse.html
No Movement When
Transmission is Shifted to Drive or Third?
http://schematicsdiagram.blogspot.in/2012/03/no-movement-when-transmission-is.html
While going in reverse mode
Fuse number 27 blows on Ford Ranger?
http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
These
will help.
Thanks.
Nov 28, 2012 | 1999 Buick LeSabre
I have a Evinrude Ficht 135 that Runs Ok but won't go in to gear, forward or reverse. Any ideas?
Disconnect the shift cable and see if the problem is with the shift box or the lower unit. If the lower, remove the bottom plug and look for water or metal where there should be clean oil.
If the shift box, take to the marina- they were a bear. Even just for cables.
Jun 17, 2012 | Light Boating
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
1999 FORD EXPERDITION TRANSMISSION WON'T MOVE FORWARD BUT MY REVERSE WORKS FINE WHAT I NEED TO DO
You can try shifting into manual 1 to get moving then once you get going shift the lever up into Drive. This should work, then drive it to a shop to have your ****** looked at.
Feb 08, 2012 | 1999 Ford Expedition
My 1998 Honda civic ex won't move but the motor
Have you just replaced the clutch? Taken out the transaxle, and put it back in? Are you sure transmission was in good condition before this? If so, review your procedure carefully to be sure you got it all back right.
Watch the slave cylinder while someone depresses clutch. You should see the little plunger move slightly out and move the clutch lever back. The lever moves the release bearing inside bell housing into contact with the pressure plate. If slave cylinder doesn't move at all, try bleeding again. The plunger has to move when clutch is engaged.
I'm not sure what you mean by "will shift but won't go into gear". You mean it's actually going into a gear position and car won't move? Or it won't go into any gear, period. As if you had no clutch?
Nov 06, 2011 | 1998 Honda Civic
My 1993 Honda accord EX , the transmission quit. auto, no gears forward or reverse.
Check the fluid level. Automatic transmissions won't go into gear without enough fluid. If it's low, you've probably got a leak somewhere that you need to find.
Jun 13, 2011 | 1993 Honda Accord
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
NO REVERSE FORWARD GEARS WORK. IS THERE A BAND AJUSTMENT FOR REVERSE ?IF I PUSH IT OFF IT WORKS BUT SLIPS
I have a 2000 Honda Accord EX, it shifts normal on forward with no problem. Also when the car is cold the reverse gear works just fine, but when the car runs for about few minutes the reverse gear will not work. It will seem as if it wants to go but then if feels like its neutral.
Oct 06, 2008 | 1988 Mazda RX-7
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
