Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
Repair manual for husqvarna yth180 riding lawn mower
Trans axel problems. sliping on hard pull
  • 6 Answers
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Posted on Apr 22, 2009
youcandoit2
  • 11 Answers
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
Posted on Jul 17, 2009
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
SOURCE: How do I install a mulching Kit on my Husqvarna
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
Posted on Jul 06, 2011
My tractor will not start, battery is good; I think I need a solenoid or starter for Model # YTH180 HUSQVARNA Lawn, Tractor
Hi there I had the same problem with my rideon mower I thought it was the solenoid as battery was new but I found that the 1 of the leads that go to the battery had worn onto the chasey making it not to start put some electrical tape if worn or replace the lead.
Oct 29, 2014 | Garden
Husqvarna Riding Lawn Mower Problem
sounds like a linkage problem or the valve in the trans some older ones had a problem with a roll pin inside the trans falls out of place cheap fix but a lot of time to pull the trans out and apart
Jul 12, 2012 | Garden
I own a Husqvarna...Model YTH180....I am looking for a new or good used deck.Will any other brand deck work on this mower?Do you have any suggestions on where I might find one? Thanks
there are mower boneyards around, you just have to look. try a google search in your state. also try ebay and craigslist. my yth 2148 looks just like my neighbor's craftsman, but the decks will not interchange.
Jul 01, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Llubrication chart for husquvarna riding lawn mower with trans axel . YTH2448
I googled yth2448 manual. A site called ubermanuals.com it came up with an operator's manual you can download.
Hope that helps.
Good Day.
Oct 26, 2009 | Husqvarna Garden
I am trying to find the owners manual for a yth180
Obviously you haven't looked very hard for it yet.
A simple Google search for "Husqvarna yth 180 manual" returns thousands of sites, the very first of which has 10 or 15 different PDF downloads for manuals for this tractor:
lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
Oct 06, 2009 | Husqvarna Garden
We have a Husqvarna Rider, model YTH180. It's
whats rough the motor if so you could have bad gas or bad plugs or somethin els you may need to get that to a shop
Sep 27, 2009 | Husqvarna Garden
Husqvarna YTH180 runs but won't go into gear
Check the drive belt. If it looks good and turns the pulley on the trans you will need to have the trans looked at.
Sam
Jul 12, 2009 | Husqvarna Garden
Is there a deck switch on a YTH180
Hi..my name is Keith...and i havent worked on that lawn mower model..so i cant tell you exactly where the safety switch is..but it sounds like the reverse safety switch has failed and the lawn mower thinks you are in reverse..so i would look around your foward-neutral-reverse shifter for it...i hope this has helped..if not write me back
Jun 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
1,717 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
