Question about Dryers
Why do i not have power to dryer start switch
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 09, 2012
Dryer
test this steps and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#electric#ixzz2Zk5oxDiH
Jul 21, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Amana Dryer Model # NED4500VQO won't start
see the following steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-1#ixzz2Yb4M1zkU
Jul 09, 2013 | Dryers
Dryer wont start
see this causes and fix it. God bless you
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details. Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Amana Dryers
Dryer not powering/turning on
Investigate these areas if your dryer is not starting: Proper Voltage from the House Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in. Door Switch If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it. Start Switch A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again. Thermal Fuse A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it. Thermostat A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective. Timer Motor Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly. Motor A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor. For more info see the following link: http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Aug 05, 2012 | LG DLG2532 Gas Dryer
Power going to door switch-light goes off and on with switch, press start switch-switch makes contact but dryer does not come on. So when on switch is pressed unit does not power on.
unplugg dryer,take the 2 wires off of door switch connect them together with electrical tape,plugg dryer back in hit start switch dryer should come on ,that tells you that the switch is bad,this can also done with a tester
Jan 23, 2011 | Dryers
Dryer has power. When the start switch is turned,
Sounds like start winding inside the motor, or a start switch attached to the motor itself.
Jun 22, 2010 | Frigidaire GLEQ642A Electric Dryer
Frigidaire Crown dryer will not start. Has power to it
Check the following to address this issue.
Jun 11, 2009 | Frigidaire Electric Dryer
Electric dryer won't start
HI, check the following to address this issue you are experiencing.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 02, 2009 | Maytag MDE2600 Electric Dryer
Estate dryer wont engage
Check the following--
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Won't start - 3 beeps when Start button pushed
CHECK THE FOLLOWING--
May 31, 2009 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
