Question about Maytag PAV2300 Top Load Washer
Maytag washer overflowing
My washer is overflowing with water and I am not sure how to get this to stop.
  • 1 more comment
  • pinevalley1 May 11, 2010
    Is it overfilling? or is it just leaking during the spin cycle? Overfilling would be caused by the filling system malfunction(air pressure is applied to a switch as the drum fills telling the water solenoid when to close. Pop the cabinet lid from the frontside and lift open. Check the clear tube on the left side behind the basket. Look at the airbell it is attached to for any obstructions. If it looks fine then the switch may be bad or the solenoid may be sticking open.
    Overflowing during the spin cycle means a possible bad top basket seal. Not a huge deal to replace. Just pop the top ring by lifting the tabs around the basket. Replace the foam rubber seal and snap back in place paying attention to which the tab alignment. Hope this helps
  • David S Jan 07, 2012
    Thank you! I had this problem and it was the pressure tube as described. It was very clogged after 12 years and in addition to overfilling, the wash size selector switch wasn't working. One additional tip to others: the pressure tube on my machine is black. It runs from the base of the tub up into the electronics panel.
  • Anonymous Mar 31, 2014
    Maytag bravos xl
  • Maytag Master
  • 8,220 Answers
Remove the tube from the water level switch. Blow it out so the sediment will stop blocking the tube. Re-attach it and pump out the water. Retry.
Posted on Jan 21, 2009
4 Suggested Answers
  • 1073 Answers
SOURCE: Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
Posted on Apr 23, 2008
capsman
  • 111 Answers
SOURCE: Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Posted on Aug 02, 2008
lavon82931
  • 17 Answers
SOURCE: washer overflowed, water all over the floor, any
you have a leaking pump and need to replace it.
Posted on Sep 14, 2009
Maytag Neptune TL washer overfilling
yes i would agree the water valve is defective as if unplugged it should close,but also sounds like a pressure sensor or pressure hose problem that is also defective too due to the fact that it should at least start the wash cycle even though the water doesn't stop filling,so also it could be the central control unit,pressure switch or pressure hose
May 07, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Washer is overflowing
The water input on washers is controlled by the timer which actuates the solenoid valves for both hot and cold water, telling them when to fill and when to close. I would run the machine thru a fill cycle with the washer back off, and with a voltmeter, observe if the voltage ever cuts off as the timer runs. I Another variable is the water level control. So also determine if that is working since if it failed to open the 'fill' circuit at the proper volume, you might have this overflow problem.
Aug 15, 2011 | Maytag Washing Machines
I have an old maytag model #LA712 top loader. Recently it has started overflowing not stopping when it's filling. This does not happen everytime and it does not leak any other times but when it does what a...
Usually this is caused by the water inlet valve sticking in the open position. If you can catch the washer while it's overflowing, unplug the washer. If the water stops, then the problem is most likely a pressure switch or pressure hose. If the water does not stop, it is most likely the water inlet valve.
May 25, 2010 | Maytag Washing Machines
At the end of cycle washer will not stop filling and overflows. maytag neptune fav6800aww
There is a diaphram switch located in the machine at the bottom right in the rear. When you remove the front panel it will be all the way back on the right. It senses the water level. It has three levels it detects. I had a problem with mine filling too much. That should take care of your problem.
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Cold water cycle has warm water no cold water allowed. sounds like some kind of valve is not stopping the hot water from coming in
Make sure that the inlet hoses are connected to the correct inlet solenoid valve (located just inside the cabinet). If the hot water solenoid was passing water when not wanted, the washer would eventually overflow on to the floor. There may be a problem with the solenoid control circuits which may require professional help to diagnose.
Feb 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Water won't cut off
if you have to shut the water off at the source you need a new water inlet valve. If not then you need to replace the pressure switch.
Jan 29, 2009 | Maytag MAT13MN Top Load Washer
Aug 02, 2008 | Maytag Washing Machines
Apr 23, 2008 | Maytag Performa LAT2500A
Water overflow
when u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Aug 19, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
1,039 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
