Question about Echo Pb403 Pb413 Pb460 Pb4600 Carburetor Zama C1m-k37d 12520008563
Pb-460 no spark
Put in new plug still no spark
    Problem Solver:
  • 13 Answers
U could have a bad magneto, or u may need to check the gap on the magneto and the gap on your plug. pull plug and insert plug into wire and rest on top of head an pull starter to see if u get spark. if not, u need to check your magnetos gap.
Posted on Apr 25, 2014
  • Dave Mazzilli Apr 25, 2014
    u could have a bad magneto, or u may need to check the gap on the magneto and the gap on your plug. pull plug and insert plug into wire and rest on top of head an pull starter to see if u get spark. if not, u need to check your magnetos gap.
How to change the spark plugs on my 2009 Hyundai Sonata 4 cyl.
remove 1 spark plug wire from the plug. Find a socket that fits the spark plug and connect it to the socket wrench. Put the socket on the spark plug and turn counter clock wise until the old spark plug is removed. Check the gap on the new replacement plug ( make sure you have the correct plug first). Put the new spark plug into the hole that the old 1 came out of and turn clockwise by hand making sure it is in straight, then tighten it clockwise until tight.( WARNING: DO NOT OVER TIGHTEN THE PLUG OR YOU WILL BREAK IT). replace the spark plug wire. repeat the process with the other 3 spark plugs. Start the vehicle. If you are replacing the wires, take off 1 wire at a time, match up the size and replace the old with the new.
Dec 27, 2014 | 2009 Hyundai Sonata
My gilera keeps needing a new spark plug
1st: Are u sure you're using the right spark? There are short and longer sparks, so check it;
2nd: Check if you're using a good oil, since sounds there are excess of oil on cylinder. Maybe changing the autolube oil could help.
Mar 22, 2013 | Motorcycles
G'day, I have a simplicity express ride on mower that was running when I got it, I've put a new battery in it, new spark plug, new fuel filter and new fuel lines. Last time I used it was running great
that video sounded like a very low battery, and, if you know your not getting spark, check the plug wires for continuity, and that there are good connection to spark plugs, once you get spark, then make sure you are getting fuel
Mar 09, 2013 | Garden
How do I change spark plugs and the coils in the 2003 grand vitara?
here is a page showing you how.
remove COPS
blow out wells to stop stand from falling inside engine.
remove spark plug.
gap new spark plug.
put back spark plug
put on new boots.
put back oil cops and see of new boots (cheap)fix cops if they are bad.
http://www.fixkick.com/IGN_timing/tune-ups.html#COP_boots
Feb 22, 2013 | 2003 Suzuki Grand Vitara
Not getting no spark to the plugs
put one of your spark plugs out and put the wire on the end and touch it on the motor and have someone start the car and if you see a spark the that is good you might have a couple bad spark plugs you might have a couple bad spark plug wires try that though and if there is no spark then ist best to just get new spark plugs and new spark plug wires
Mar 02, 2012 | 1995 Oldsmobile Cutlass Supreme
How to change spark plugs?
First go buy the new spark plugs. While you are there ask the gap of the plugs, they may need to be adjusted before you install them. If so use a gaping tool to adjust the gap. One at a time remove the spark plug wire and remove the old spark plug with a spark plug socket. Turn it counter clockwise. Pull it out and put the new spark plug in and firmly tighten it, dont over do it though you dont want to strip it out. Put the spark plug wire back on and move to the next until the job is complete.
Jan 15, 2011 | 1994 Ford Ranger Supercab
I have 5000mtm pressure washer ,starter wll not turn over and there is spark to to starter,what do yo think
Take out spark plug
Put cap on spark plug
Hold spark plug by spark wire
Put spark plug threads against edge of hole where spark plug came out. Metal to metal.
Pull start cord.
Look for spark between metal
No spark, then you need new spark coil from small engine repair shop
Oct 15, 2010 | Mi T M WP-2700-4MHB Pressure Washer
My neighbor gave me a Poulan mower that doesn't work. I am trying to trace the problem but don't really know what I am doing. It doesn't start. It has a new spark plug that I can only assume is gapped...
Remove plug, with plug wire connected to plug ground plug to the head and pull you should see a spark. If not if your mower has safety swithes you may have to jump around them.Or relace ignition unit. If you got a spark, try putting a little gas in the spark plug hole before putting plug in. If it pops then you probably have a fuel problem.
Sep 28, 2010 | Poulan Garden
No spark I put new spark plug and gaped new
check the small wire coming out the magneto maybe it is grounding out somewhere, disconnect it from trhe magneto and then see if you have spark
May 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Echo Pb403 Pb413 Pb460 Pb4600 Carburetor Zama C1m-k37d 12520008563 Logo
294 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
