Question about Frigidaire FES355 Electric Kitchen Range
How do i get the front panel off?
I need to change the control board
  • Frigidaire Master
  • 15,691 Answers
You need to pull it out from the wall and take the back off. Make sure that you have it unplugged.
Posted on Nov 04, 2012
What is control board assemble and how can I see it?
The control board is on the front panel and you will need to remove the front panel to get access.
Please check this link Control panel How to Diagnose Washing Machine Control and Program Problems
May 04, 2015 | Washing Machines
DD605i touch panel no longer responds. Service guy came and advised on a new board. My wife noticed that he was able to change the wash modes using the from rectangular panel with the power, lock and
What he did from the front panel was put it into a service diagnostic mode. This will not help you as it does not let you run a normal wash cycle from this mode. Most likely the controls are not responding because the control board is not being held up tightly against the underside of the panel. If there is a gap, the buttons will not respond. You may be able to wedge something under the mounting tabs to force it up tighter. You have to take the front of the door off to do this.
Aug 09, 2014 | Fisher and Paykel Dishwashers
I need help changing the remote control sensor on my tv set, model vo47L, any sugestions?
The remote control sensor is a three solder terminal component, can be located just behind the infrared window at the front panel of your TV. You have to open the TV, and unscrew out the front panel circuit board to replace it.
Will look like this.
Jul 22, 2012 | Vizio Televison & Video
Change control board on Frigidaire washer LTF2940ES3
This is typically not a DIY type of job since the entire front, top, panel where the settings are needs to be taken apart to reach the control board and wiring harnesses.
Jul 19, 2012 | Frigidaire ATF6000ES Front Load Washer
Neptune front loader. doorlock light quit working. wont spin.
You will need to change the machine control board and door lock wax motor.
MAH3000AWW PART # 'S 22002988 AND 12002535
MAH4000AWW PART# 'S 22002989 AND 12002535
If yo look at your control board in the control panel you will find R11 burned.
Jun 10, 2011 | Maytag Washing Machines
I'm trying to remove the front panel on my front load washer. The model number is WFW 9200 SQ 01. How do I change that electronic control board that is behind the buttons you press to opperate it?
you dont need to remove the front of the washer to get to the control board. remove the top panel by removing the screws at the top in the back. top panel should now slide off. control board will now be visible.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
No power, even though it is plugged in. The breaker box had no flipped fuses.
they can trip inside you can't see it so flip them on ...off fast and hard push off very hard to reset
Aug 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
There is no power on the unit although it is plugged into a live outlet.
Possibly you have a burned out control board or a burned out control panel. I had a similar problem. I changed the control board first and it ended up being the front control panel.
Nothing worked on the front panel. No lights came on and no beeping sound when you pushed any button. I should have done the front panel matrix test first in the manual. But the manual lead me to believe only one button or one light would fail. For some reason the whole front panel stopped working.
If you problem is the same. Do the matrix test on the front panel. If it checks out okay then it's your control board. I believe if the motor control board is the issue you would still see the front display working.
The fuse is on the motor control board. Do not try checking anything till you view the manual below.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Aug 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How do remove front seal on my ultima wf865
Remove top cover, unclip the control board, and unplug the lead to the board, remove screws holding board and remove same.
Remove front panel screws, remove screws holding door lock,remove clamp securing front seal ,remove seal, slide panel up and remove.
Change seal.
Re-assemble in reverse order.
Please rate my solution.
Thanks.
Jul 29, 2009 | Hotpoint Ultima WF865 Front Load Washer
Can not change Cycle setting
I wonder if it's the control board that needs replacing ??? found a note on www.managemyhome.com saying...(part no 134207700 according to my parts list). Is there anything unique/special in replacing the control board... here are the instructions for it...if you try this, pelase let me know...
Replacing the control board is just a matter of removing wires from the old control board and installing them on the new one. It is an electronic board and can be damaged by static electricity so you have to touch some ground points with you hands before touching the control board.
To access the control board remove the top panel from the washer. There are 2 screws in the rear of the washer holding the top on.
With the top removed you will see three screws going down from the top holding the control panel to the cabinet of the washer; remove them.
Lift the control panel up and it will come loose. The control is mounted to the control panel with some screws.
Oct 07, 2008 | Kenmore 44072 Front Load Washer
Frigidaire FES355 Electric Kitchen Range Logo
60 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
