Question about Dewalt DW0521 Quick Connect Impact Driver Conversion Chuck
How to Remove Bit from Dewalt Quick Connect Adapter DW0521
Lost the darn instructions. How do I remove the bit? I'm holding the chuck and have it in reverse. No go
Thanks,
Anna
  • joesss Jan 23, 2009
    This is the first time I've used my new DW0521 Quick Connect Impact Driver Conversion Chuck. I inserted a bit, tightened it up and used it. When I went to remove the bit the chuck just spins and does not release the bit. Am I missing something or is their a trick to it. My bit is still in the check. Maybe it is defective.
    Anyone have one of these?
    joe
Hold the chuck by its sleeve, put the drill in reverse (make sure it's set at high torque if you used it in a drill/driver) and go full speed. That should release the bit.
Posted on Jan 29, 2009
  • 2,176 Answers
Can you provide the model number. Or if you want go to Dewaltservicenet.com with the model number and you can download the instruction manual. Let me know.
Posted on Jan 06, 2009
Dewalt instruction manual
The black thing at the end is the "keyless chuck". Grasp it just behind the silvery tip of the chuck with one hand, and grasp the knurled ring just behind THAT area with the other hand. Twist the "front" hand counterclockwise while you twise the "rear" hand clockwise. That will loosen the chuck so you can change bits.
Aug 06, 2014 | Dewalt Dc987k2 Xrp 18volt 12 Drilldriver...
How do I open the chuck or drill mouth to replace the drill present in my DeWalt Heavy-Duty 3/8? Keyless Chuck Drill?
Hi Tony,
To remove the bit with a keyless chuck, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck.
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 19, 2011 | Dewalt Drills
I have a DEWALT DC920 drill-driver and have a bit stuck in the chuck. The chuck adjuster appears to be stripped. Need to remove the bit and replace the chuck. Any ideas on how to get the bit released?
try tapping on all sides of the chuck lightly with a hammer and wiggling the bit... you can also try to spray some oil into the chuck and see if that loosens the bit for you... You can also clamp the bit in a vise (or get someone with a pair of pliers) and pull, that will sometimes do the trick.
Apr 04, 2011 | Dewalt 18 Volt Compact Drill Kit
How do i remove the bit from the drill
There are to parts to the chuck. You hold the ring at the edge of the chuck from turning, and then you turn the part after that, ccw to release.
Jan 30, 2011 | Dewalt 18 Volt Compact Drill Kit
Remove existing phillips no chuck avalible in this model
Take a phillips screw driver and stick it into one of the key holes. Then take a flat head screwdriver and stick in one of the slots. And prise against the phillips.
Or you can wrap a belt or strap around the chuck hold it tight, then put the drill in reverse and unscrew it.
May 30, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Removing centre screw from chuck
Drill a hole in the top of the phillips head screw with a 3/16 th's bit. Don't drill the head of the screw off, just drill deep enough for a torx bit to hold. Take a T-30 torx bit and tap in into the hole you have drilled. Then turn the screw clockwise and it should come out fairly easily.
Mar 26, 2010 | Dewalt Drills
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How do I ''unlock'' and twist to change a drill bit
hold the drill so the handle is facing you and the drill bit is facing away then twist the chuck clockwise. some quick chucks have two halfs in which case you hold the back collar (nearest you still)
if its really tight it the drill bit into the chuck with something soft like a piece of wood so as not to damage the drill
Jan 10, 2010 | Dewalt Drills
Can't remove bits
I had this problem on my De Walt DW912- I simply couldnt turn the keyless chuck to remove the screwdriver bit and there was no obvious reason why.
I placed the unit on a solid surface so that the chuck/ drill bit was pointing vertical. I then used a mallet and a metal chisel to gently tap each of the 3 chuck jaws back into the chuck body. It worked!
Turned out that there was the absolute tiny amout of corrosion between the jaws, and the chuck and my tapping had just broken the siezure. I now remember that it started to rain slightly last time I used it.
Some spray release agent or perhaps WD40 would probably have done the same job but I wouldnt have believed so little corrosion could have done this so didnt realise this was the problem.
Mar 17, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt DW0521 Quick Connect Impact Driver Conversion Chuck Logo
2,174 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
