Question about Chaney Accurite Wireless Atomix ClockThermometer with Sensor
How long to I have to wait for an atomix battery operated clock to reset itself
None
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
Had to change the batteries in the Atomix clock and now the
Hello
What is the Brand name and Model number of your Atomic clock?
Jan 04, 2012 | Audio Players & Recorders
Resetting to daylight savings time.
The clock is searching for a strong enough radio signal from NIST station WWVB. When it can't lock on it, it gives up, moves the dial four hours, and goes to sleep to wait for better reception. Put the clock in a window facing towards Boulder, CO, overnight. (Radio propagation is better after dark.)
Mar 08, 2009 | La Crosse Radio Controlled Atomic Clock
Time zone
Hi - You can download the manual from the link underlined in blue below:
Chaney
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 13, 2008 | Chaney Instrument 13130 GM Atomix Digital...
Replaced batteries= how to set clock -time, etc/
• Twist and lift open the battery compartment cover at the back of the clock and insert 1 fresh AA, LR6 1.5 volt ALKALINE battery according to the polarity marked on the case.
• Press time zone button to select a time zone.
• Replace the battery compartment cover.
THAT’S IT! During the night your clock will automatically set itself.
It will do it itself just need to wait thats all
Apr 21, 2008 | La Crosse Radio Controlled Atomic Clock
Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
Chaney Accurite Wireless Atomix ClockThermometer with Sensor Logo
27 people viewed this question
Top Chaney Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Chaney Measuring Tool and Sensor Expert? Answer questions, earn points and help others
