Question about Hitachi 50V710 50" Rear Projection HDTV-Ready Television
Where are the fans located on a hitachi 50v710 tv?
I was watching my tv when it suddenly shut off. When I turned it back on there was no picture or sound and my temp and lamp lights were blinking. I don't know where the fans are located to see if that's the problem.
  • 927 Answers
SOURCE: Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Posted on Sep 09, 2008
SOURCE: hitachi #55VS69A
I had this same problem over the summer, I had my TV for two years before it went out. You need a new lamp. The lamp is not hard to replace on your own. However, you MUST make sure that you do not touch the lamp (the bulb part) in anyway. If you do your new lamp will not last as long. You can order the lamps online. They range anywhere from 150-300 dollars online. However, I found a TV repair company in my city that only charged me 100.00 for the lamp and they told me If I took out the box that holds the lamp they would replace the lamp for me. They also gave me a 1 yr warrantee on the lamp. All I had to do was un-screw the box from the back of the TV take the box to the TV repair company and I placed the box back into my TV. My TV works. While going through this process, I learned that these lamps go out all the time, the more you watch the TV the more often you'll replace the lamp. I was told from the repair company it could be as often as every year. The Lamp does have MURCURY in it so if you replace the lamp on your own be careful and have it recycled. If you live in SLC UT the repair company I went though was Village TV Sales and Service.
Posted on Dec 07, 2008
SOURCE: Hitachi 55VS69A , just turned off while watching.
video is not coming but audio is coming
Posted on Jul 17, 2009
  • 2187 Answers
SOURCE: Hitachi 43FDX20B, watching tv, screen went blank,
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Posted on Jul 24, 2009
  • 101 Answers
SOURCE: When I turn the TV on, the Lamp and Temp lights
How long has it been since the lamp has been change? If the lamp went out, this would cause this problem.
Posted on Nov 11, 2009
Hitachi 50V710 Greenish Tint
Make sure that there is no Magnetic feild around the LCD
Sep 06, 2008 | Hitachi 50V710 50" Rear Projection...
My temp light keep blinking
When the temp light is blinking, that indicates that one (or more) of the cooling fan has stopped spinning. The TV will stay off to protect itself from overheating until the fan is replaced. There are two fans. One is available here: http://www.encompassparts.com/products/?GS01131 ; the other is http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/GS00931/New.aspx .
Retrevo has the manual for the Hitachi 50V710 here: http://www.retrevo.com/support/Hitachi-50V710-TVs-manual/id/372ag010/t/2/ . You will need to enter the code to access the file.
I hope this helps.
Sep 14, 2011 | Hitachi 50V710 50" Rear Projection...
Where is the lamp located on my 50v710 Hitachi TV
The lamp is located behind the lower removable speaker grill on the front of the TV. There will be a lamp door then the lamp is up inside the TV behind the lamp door. Make sure the lamp door is back in place before turning on the TV after replacing the lamp as the set will not work without it installed.
Mar 02, 2010 | Hitachi 50V710 50" Rear Projection...
I have a Hitachhi 52
Sorry to say, But its probably the light engine.Hitachi has had big problems with this, its all over the net about this kind of problem. If the set is not very old, you may try to call Hitachi and complain, They did replace mine in my 50V715 but I had to pay a service call of $300 to have an authorized dealer replace it. Hope this is helpful.
Oct 17, 2009 | Hitachi 50V710 50" Rear Projection...
Cable men blew tv lamp arguing that it wasn't their fault
I feel like you explained it quite clearly this liquid mercury lamp in your set has to cool down by way of the lamp fans or it can cause them to prematurly fail.
Sep 02, 2009 | Hitachi 50V710 50" Rear Projection...
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
I have a Hitachi 50v710
You have a defective light engine and here is what you need to do...we just went through this. You need to call Hitachi's customer relation department at 800-654-7013 and tell them the problems your having and that you think it's a defective light engine. They will initially act like they have no idea what you're talking about but will give you the names of some certified dealers in your area to call. Once you have a tech out from the dealer and they confirm the light engine problem (takes less than a minute) call Hitachis customer relation department back and tell them that a certified tech confirmed the problem. All of a sudden, Hitachi will say they are aware of the probelm...imagine that!
Hitachi will call the dealer and confirm this with them and they they will send the light engine directly to the dealer and Hitachi will cover the cost of the part (around $1500). All you will pay for is the install. Our install was $400...worth it to us since we paid $3600 for this TV 3+ years ago and it's been a great TV.
DO NOT let the dealer tell you that you will have to pay for the part. Hitachi knows about this problem all to well and they are replacing the part for free.. Again, you only pay the install. Please deal only with the customer relations department at the number I listed above. If you deal with their regular customer service people, they will have you chasing your tell. Hitachi customer relations will take care of you! Good Luck!
Dec 08, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V710 50" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
