Question about Ken Tech Large Digital Atomic Clock
Ken tech atomic clock didn't reset when dst started
SETTING THE TIME
Check to verify the correct time zone and/or DST has been selected.
Jun 03, 2016 | Ken Tech Large Digital Atomic Clock
HD1688 MANUAL
it does not need setting when you put batteries in it, it sets itself, all you can adjust is the DST function
Mar 23, 2014 | Ken Tech Large Digital Atomic Clock T4668
Our atomic weatherstation/clock has never reset to DST
I had the same problem with my atomic clock. Had to move it to a clear area, one without obstrucions. It set itself almost instantly
May 26, 2011 | La Crosse Radio Controlled Atomic Clock
Cannot get my atomic clock to reset to proper time
Make sure that it has fresh batteries, set it for the correct time zone, set the DST switch to ON (unless your time zone does not use DST), then place the clock on a solid surface, outside if possible, so that the face of the clock is pointed roughly towards Fort Collins, Colorado. It should reset in a couple of hours - or less.
Aug 07, 2010 | SkyScan 86709 Atomic Wall Clock
Silicon scientific atomic projection clock did no reset for daylight saving. Help
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
May 19, 2010 | Watches
RCA atomic clock radio didn't reset to DST
Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
Mar 09, 2009 | RCA RP5430 Clock Radio
My atomic clock did not change time when it was supposed to.
Are you talking about your clock? Maybe a Timex T311T or Kro** or whatever. The auto clock sync did **t work for a lot of atomic clock owners, ** one is saying why. But the idea of DST brings a lot of tech**logy into play. And some atomic clocks are well k**wn for this problem.
Mar 09, 2008 | Computers & Internet
Daylight savings time
so long as the US atomic clock adjusts their daylight saving times then you should be fine check this link for some more details (about the scr 110 but seems to be basically the same) http://www.amazon.com/H-H-Scott-SCR110-Atomic-Clock/dp/B00004TZDN/ref=sr_1_2/104-1966292-9407907?ie=UTF8&s=electronics&qid=1173502881&sr=1-2 hope this helps :)
Mar 10, 2007 | H.H. Scott SCR120 Clock Radio
Ken Tech Large Digital Atomic Clock Logo
672 people viewed this question
Top Ken Tech Audio Players & Recorders Experts
cwradio73
Bart Walker
Tom Chichester
Are you a Ken Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
