Question about Dryers
How to open top of dryer to get inside - Dryers
  • N. Brody Nov 04, 2012
    Why do you need to get inside of it?
  • monique duquette Nov 04, 2012
    when the drum turns it makes a noise
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Most likely you would need to access it from the back of the bottom of the dryer.
Posted on Nov 04, 2012
Where is the thermal fuse located on this dryer? please
Hello Leslie
I don't know what is the brand of you dryer. I will make you a preference this brand.
In GE dryers, the thermal fuse--sometimes called a safety thermostat--is located behind the drum on the inside of the dryer. To access the thermal fuse you will need to open the dryer from the top. Though it may sound a bit daunting, opening the top of the dryer to reveal its inner workings is surprisingly simple. To open the dryer top you will need a flat-head screwdriver, putty knife or similar tool. Insert the screwdriver or putty knife underneath the dryer's top panel. Slide the putty knife along the bottom of the panel until you locate the two clips that hold it in place. These clips are usually located about four inches in from either side of the top dryer panel. Apply pressure to the clips to release them. Once the clips have been released, lift up the top panel and use the supports to keep it upright. Look inside the dryer, behind the drum, to find what looks like a round metal pan. This metal pan is actually the dryer's heating element housing. The thermal fuse will be located next to the heating element housing. Look for a white strip with two wires connected to it and you've located the thermal fuse in your GE dryer.
Best Regards
Neciforo Llanto
Oct 01, 2013 | GE Profile DPSB620GCWW Gas Dryer
Sears kenmore dryer model 4179842990
Big job.
The top comes open with a small screwdriver, or better yet a putty knife slipped to the right and left front corners and pried up. You have a plastic clip on either side of the front top which will snap open when pried.
Then, the front of the machine is usually held on with two screws that are inserted into the top front from the top sides, one screw in each side.
The bottom is easier, once the top screws are out, you lift the whole front panel off.
Down at the bottom of the front panel are two clips that go in two holes to hold the panel on.
You will also be unplugging the wire connector to the door switch.
We also had this happen, and if turning your clothes inside out or tying the strings doesn't work, we found to put such items inside a mesh "unmentionables/undergarments" bag stopped the problem.
Be blessed.
Apr 01, 2013 | Whirlpool Dryers
How do you open the top? the padals inside the drum are coming loose
The front panel needs to be removed first before the top cover can be lifted to the rear of the dryer to access the outside of the drum and re-tighten the screws attaching the baffles to the drum. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Aug 01, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
A paddle inside drum is loose, need to open top of dryer
first take the door out from the hinges then the frame around the door the you can open the top or the front of your machine...
May 01, 2010 | Maytag Neptune MDE5500AY Electric Dryer
One of the plastic pieces inside the dryer drum is loose. How do I remove the dryer top so I can tighten the screws>
OPEN THE DOOR. INSIDE THE OPENING ARE FOUR SCREWS 2 ON EACH SIDE. REMOVE THESE. EACH SIDE OF THE FRONT PANEL KIND ROLL OF FROM INSIDE TO OUT AT THE TOP. OR JUST PULL. BRING THE FRONT PANEL OUT TO A 45 DEGREE ANGLE. CLOSE THE DOOR AND LIFT UP ON THE FRONT PANEL. AT THE FRONT OF EACH TOP CORNER THERE ARE HOOKS HOLDING DOWN THE TOP. THEY ARE SCREWED IN PLCE WITH A 5/16 TH HEX HEAD SCREW. REMOVE THOSE AND THE TOP CAN LIFT UP.
Apr 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
I have a Kenmore gas Dryer (stile #2) with the door that opens in the front. Inside the dryer, there are three blades (parts) that help the cloths turn. One is comming off and I noticed that the blade is...
you can take the top off there are screws in the back and clips on the front if you push on the clips with a flat screw driver lift the front edge and push the clip the top will tip up when you free the clips
Oct 20, 2009 | Kenmore 73952 Gas Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Ge dryer
Jim; without the model number it is hard to give specific advise. (model number is usually on the frame just inside the door) To open top, try pushing a putty knife in the seam between the dryer front and the dryer top, a few inches in from each side.
Nov 06, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
