Question about Sony STR-DE197 Receiver
Sony STR-DE197 Dead
My Sony STR-DE197 stopped turning on. I opened it up and found one of the two 5A 125V fuses blown (F901). I replaced the fuse and re-powered without any connections. The fuse immediately blew again. No visible signs of other damaged components. Any thought on what could be shorted out?
The unique thing about this amplifier is that I use it to power a whole house audio transformer (Niles Audio Transformer). This is intended to match output impedance but I'm guessing it still pulls more power than typical applications.
3 Suggested Answers
  • 5 Answers
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Posted on Mar 19, 2009
SOURCE: Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
Posted on May 27, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have the same problem. The fuse blows every time
There is usually one or two normal clicks on power-up. A self-protection relay activates after a short delay for circuit and power stabilization plus some internal cheking for shorts and thermal issues.
If it keeps blowing fuses you are stressing it a bit more every time you feed it another one. I'd get it in to a Pro for repair.
Posted on Mar 02, 2010
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V...
I have the same problem. The fuse blows every time I plug the Sony STR-DE135 into the wall. I did not find the F901 at Radio Shack, so I bought a fast acting 5 Amp 125V Fuse at the Hardware store. It blew...
Mar 02, 2010 | Sony STR-DE135 Receiver
Sony STR-DE945 8A 125v fuses
Check HomeDepot they have 7amp , maybe your store has 8amp.
Dec 18, 2009 | Sony STR-DE945 Receiver
May 27, 2009 | Sony STR-DE635 Receiver
Microwave stopped working when i pushed the start button
Yes. The white inside the glass that you are describing is a blown fuse. To find out what size fuse it is look around the base or top of the fuse. You will see engraved something like "125V 5A. You can pick these up at Home Depot or Lowes in the electrical isle. You can also type www.google.com and enter the word "fuse" and then the size it is. (125V 5A) If you have found this information at all helpfull, please rate my solution. Thanks D. Lange
Apr 23, 2009 | LG Microwave Ovens
Sony str-de845 Powers up, relay clicks, fuses BLOW!
Mar 05, 2009 | Sony STR-DE845 Receiver
Indentifying fuse type on tac0151 chassis
Are just regular fuses 5A/125V. You can replace them with anytype 5A fuses.
Jan 05, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 TAC0151 Blowing Fuses, I Need schematic
Well without the schematic, knowing Toshiba they have alot of convergence problems, so see if the fuse blown in the convergence area, if you you may have to replace convergence amps. These are the big STK's. Most of the time there was a color problem with set before going out. If no problem with this on your set then look in the HV area Hor. and Ver. area. Hope this helps!
Sep 09, 2007 | Toshiba 50H81 50" Rear Projection...
Sony STR-DE197 Receiver Logo
125 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
