Question about Danby Dehumidifiers
My dehumidifier beeps all the time - Danby Dehumidifiers
I have a 580.54501801 dehumidifier and it shows a code of 01 on the display and doesn't do anything after that but beep 2 times. What does that code mean and is it worth sending it to a shop to be...
Its not worth sending it to the shop! Dehumidifiers are made extremely cheap dont waste your money you will regret it later trust me. Sounds like circuit board issue costs almost what a new one runs.
Jun 23, 2011 | Kenmore Dehumidifiers
My dehumidifier keeps beeping??????
The water tank is either full or not positioned correctly. Empty the tank and/or make sure it is positioned correctly (should fit perfectly and not bump out from rest of unit).
If you have it connected to the drain directly, your tank may still be filling up unless you have the PUMP button pressed (and PUMP is showing in the LED screen).
Good luck and please rate me.
-mark
May 05, 2011 | DeLonghi DE400 Dehumidifier
Bucket is empty but it is beeping
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Apr 08, 2011 | DeLonghi DE400P Dehumidifier Dehumidifier
I plug in machine and hear a beep. Nothing works.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 16, 2011 | LG Goldstar LD65EL Dehumidifier
My dehumidier keeps beeping
Check the filter and make sure that the water level is correct. If all is correct then replace the water level sensor
Feb 14, 2009 | DeLonghi DE400 Dehumidifier
Dehumidifiers Logo
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
