Question about Denon AVR-1100 Receiver
How to connect an amplifier to a pc - Denon AVR-1100 Receiver
I picked up a set of CTX speakers at the Goodwill store yesterday. Today when I went to hook them up to my computer, there is no cable to connect the speakers to the computer. What cable do I need?
Most likely your speakers are not "computer speakers", but ordinary "hi-fi" speakers. They do not have built in amplifiers like computer speakers have. You will need an amplifier or receiver, and a cable to connect your computer to the amplifier (mini plug to 2 RCA connectors). The speakers connect to the amplifier, too.
Nov 18, 2016 | Dell Computers & Internet
Connect yamaha ax 396 to pc
Think aux sockets are line IN, on PC line IN too. Try finding line OUT on amp.
Nov 21, 2013 | Yamaha AX-396 Amplifier
Which input for laptop audio?
You can connect a powered stereo speakers or amplifier to your laptop for better sound. Connect an audio cable from the headphone socket on the laptop to the powered stereo speakers or amplifier audio input.
Jul 01, 2012 | Toshiba Computers & Internet
Hooked up to TV but can't get the sound leads to work. No sound from TV?? Can anyone advise please? Lorna x x x
u cant get sound from TV linked to PC.....as the PC's sound system use a RF connection...it does not have a amplifyer...the sound system travel in two formats....non-amplified and amplified....the sound sent from PC/Laptop it's already amplified...but the TV connector can receive only non-amplified signal(say from a DVD player, camcorder, music system etc)...it cant process the signal from PC/laptop......you can connect ordinary speakers ment for laptop to the sound out jack in the PC/laptop and use the TV to receive the video signal....from PC
hope this helps
Kris
Mar 01, 2011 | Acer Aspire 1642ZWLMi Notebook
Schema se-hd51 per il collegamento di un pc all'amplificatore
You want to connect your PC to your amplifier? All you need is an RCA to 1/8in cable.
Si desidera collegare il PC al vostro amplificatore? Tutto ci? che serve ? un cavo RCAper 1/8in.
Jan 01, 2011 | Technics Audio Players & Recorders
I have sony laptop ; i want to connect speakers with .i have a question that if i do so then i need a amplifier or not ? if no then how much its max output?
No you dont need an amplifier. You can connect speakers without amplifiers to it. Even 2.1 and 5.1 can be connected without the amplifier. The max output will depend upon the speaker ratings, but I can guarantee you'll get sound enough to break your window ;)
I've connected like wise without amplifier and its working great.
Hope this helped. Rate it if it helped you.
Apr 18, 2010 | Computers & Internet
How connect to computer
prepare the following item from( radio shack):-
1-3-ft gold series stereo y-cable(42-2550).
2-two of-mono phone jack to1/4 inch mono plug.(274-320).
connect item number(1)in speaker out in your computer(green socket).
connect item number(2)in the free jacks of item number(1).
connect the two jacks in two channel of amplifier in(line in)
Nov 21, 2009 | Yamaha Audio Players & Recorders
I only have the big speaker not 2 small ones that actually go with it so I'd like to know how to hook it up to my pc and what other speakers may be compatible
Connect the sound card of the PC with a recommended amplifier and then connect your big speakers to the amplifier, you can get the big speakers working. Note that the amplifier watts must be in respect to the maximum watts of your big speakers. Either the amplifier should have more watts producing capacity than your speakers or should be of the same watts in order to give you full output volume.
Sep 12, 2009 | Audio Players & Recorders
Connect cheap speakers to a new amplifier
You need proper speakers,pc speakers uise mini headphone jacks,wrong termination for an av amp
Dec 21, 2008 | Plantronics MX10 Computer Speakers Use w/...
Boston BA7800 PC speakers
I would not suggest it. PC speakers generally have their own amplifier built into the system and will not handle the power from a home system well.
Jan 30, 2008 | Boston Acoustics (BA7800) Computer...
Denon AVR-1100 Receiver Logo
19 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
