Question about Candy 17 in. CS455 Built-in Dishwasher
Washer keeps stopping mid cycle
For a while now, my candy non-built in CS455M washer keeps stopping itself mid-cycle. I have checkecd all the water inlets and outlets, and those are alright. The problem just came about suddenly, and has gone on for a while. Can anyone please help? Thanks
  • JAEL OYIEKE Jun 02, 2007
    This guy who charges nothing for call-outs had alook at it and decided that we should bin it. Major leak in a pipe.
    Thanks
    Sergeant:
  • 236 Answers
Possible heat element has gone.
Posted on Jun 01, 2007
Candy washer dryer cmd46 stopping mid cycle
your info is too sparse pat what cycle what point in the cycle
is it full or water is it rinsing ???
Aug 19, 2014 | Candy Washing Machines
Does not spin out clothes, keeps running in water as long as spin is enabled and does not follow cycle selected.
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Sep 30, 2012 | Haier XQG50-QF802 Front Load Washer
Candy cs455m programe stops at about 3oclock on the dial
Yes heatr should be submerged in the water. Not expose to free air.Check the water level float switch or the pressure switch.
The replace timer should be identical in design. If there is a mismatch it will not function as designed.
If it is elctronic micro controller type the same part no and soft ware version should be used.
May 25, 2010 | Candy 17 in. CS455 Built-in Dishwasher
C514 STOPS mid cycle
I'm having the same problem. It's new and it did it with the first wash. Can anyone help.
jackie
Jul 15, 2009 | Candy CNW136 Front Load Washer/Dryer
CANDY cs455M DISHWASHER
Hello penny123
Welcome to fixya.
My name is Huuum at your service.
You said, " YOU HAVE NO MANUAL AND NOT SURE WHAT THE SETTINGS ARE FOR."
I found the site where you can read or download your proper User manual for the
Candy CS455M Dishwasher.
Below is the site that will take you directly to the Candy online Manual search.
When there, Manually start typing in the sc455 and a few model choices will pop up.Choose your cs455m and when it opens , you may print it or just read it to acquire the information you need.
http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=3
Please Remember to leave a solved rating for me, before you leave our fixya site.
Thank You Huuum
Sep 30, 2008 | Candy 17 in. CS455 Built-in Dishwasher
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Washer/dryer stops mid cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Mar 02, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy Dishwasher CS455M
i have just bought a candy dishwasher cs455 and have no manual can you tell me the best wash and what to set it on thanks
Aug 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Candy 17 in. CS455 Built-in Dishwasher Logo
709 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
